Bumper bolts, no fun
  • profbooty
    • 308
    So my 1990 survived a deer colission and the front bumper is still in decent condition. The thing is I need to take the bumper off to replace a fender.
    One bolt spins in place past a certain point. I assume the nut is probably spinning as well, but there isn't a way to get a hand behind the bumper to stop it from spinning. Nor is the bolt far enough out that I can get some channel locks/vice grips on it and pull while spinning to use the magic of friction.
    The other bolt is in sorry shape. It came out in the past, but I should have used a torx in the past on it, so the head is all messed up. I can't get a good enough grip on it to put in a t55 and get it out.
    Any suggestions asides from cutting the bumper up?
  • SpiritualPlum
    • Feb 2011
    • 40
    Why do you need to remove the bumper to take your fender off? I removed my driver's fender without moving the bumper at all (I have diving boards by the way)
    Just tryin' to feed the e30 need.
    • Tha Driver
      • Feb 2011
      • 61
      Maybe you can take the bolts out that hold the shock to the frame & slide the bumper out far enough to get to the fender bolts?
      ~ Paul
      aka "Tha Driver"
      Giggle Cream - it makes dessert *funny*!
