Plastidip white vs. Alpineweiss II
  • tttoon
    • 275
    I'd like to paint my volvo lip again since the paint is flaking. The lip is pretty flexible so I thought plastidip would be a good idea. Does anybody have any experience with the white plastidip? How does it compare to AWII? Would the color difference be too ghetto?
  • Jand3rson
    • 37587
    I can guarantee you, with absolute metaphysical certitude that it's not going to be anywhere close to a match.
    • unrlmth
      • 467
      The AW is a much warmer (if that makes sense) color than most generic whites. Maybe test on something else first and see if it matches well enough for you.
      1989 325i Alpineweiß II
      • Asbradley21
        • Jun 2008
        • 1938
        Use black.
        S54B32 swap in progress. Status: Getting There
        • tttoon
          • 275
          I'll try some on a piece of plastic if I can find a can and post results. Black will reduce lip awesomeness by 50% at the very least.
          • khalild
            • Jul 2009
            • 310
            get a rattlecan of bmw 218 touchup paint.. can be had for under $30 if u look hard enough
            • Mossman
              • Apr 2006
              • 1961
              There's a krylon fusion called I BELIEVE dover white that I found at walmart once. Damn good match actually (for a generic spray can color) and the fusion goes on easy on just about any surface, and way better for plastic stuff like your lip than most paints.
