Noticing some water coming in to the jack area when it rains pretty heavy here in the gulf coast. I saw some water on the tail light. I pulled the tail light off and repositioned the seal/gasket and it was dirty and not fitted pretty well.
Can I just replace the gasket with a generic rubber gasket from home depot? or do I have to order the OEM one.
Also, the plastic trim piece that goes over the rear door is loose. This might also be the culprit.. or not!..
Thanks in advance.
Thanks in advance.
