Trunk popper/Actuator/Power release solenoid
    Has anyone installed one with an aftermarket key-less entry system, or with an auxiliary alarm unit? My trunk only has the actuator that locks or unlocks all the locks in the car. I would like to add a trunk opener function.
    Dude, search is your friend. Check the stereo/electronics forum. If you still can't find what you are looking for then look up Stereoinstaller1 (one of the mods) who can help you with your alarm install or at least point you in the right direction.
    Parts Collector and Former Houndstooth interior junkie.
      Not looking for alarm installation information, looking for information if people have installed a trunk opening system. pros/cons...difficulty/possibility.
        Anyone?
          I want to see someone pull off trunk pop in an E30.
          I have takes apart one, had all the parts in my hand. I just cannot see a way to pull hard enough on the mechanism to make it work...unless it stuck out a foot into the trunk!
          I have tried bellcranks and pullies. I have tried several different types of actuators. I gave up years ago.
          Feel free to try it yourself, and post pics if you succeed!
          GL!
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
            Maybe something like this?
            jag
              Originally posted by rooster View Post
              Yeah, OK, that is an actuator. What you gonna do with it?
              Closing SOON!
                The trunk release is a push system and these actuators pull mostly and there isn't enough room for the mechanism to be pulled. I have taken my trunk release/lock system and looked and looked to no avail.....I quit!
                  Survival skill #318 - How to escape from a latched E30 trunk
                  Don't give up. I've been busy but I went downstairs and took some pics for reference, here's how I'm going to do it:
                  Trunk latch open from top
                  Trunk latch open from inside trunk
                  Trunk latch closed from top
                  Trunk latch closed from inside trunk - note the little metal nub that has dropped down!!
                  Lift this metal nub and the latch will open!
                  The DEI 524N actuator I'm going to use will push OR pull and then return to center. You can choose between push/pull by reversing the polarity to the actuator. I'll set it up to push. Here is a bad photoshop diagram of how I imagine it will be installed:
                  This should work as long as the trunk is already unlocked.
                  balticblau-metallic '84 318i 5spd 3.91 LSD
                    Most every alarm will allow unlock on aux as a configuration setting.
                    Climb into the trunk and push up on that latch while it is closed, see how much force is required...I wanna see this work!
                    Closing SOON!
                      Might want to also make sure you do this with someone outside the car just in case you get stuck inside for some reason.
                        No, that's silly. Just make sure the garage is shut, make sure you are all alone, climb in there and close the lid, you will be fine. Don't worry about having a fully charged cell phone with you either, you are just being superstitious.
                        Closing SOON!
                          Make sure the car is running, too. Maybe even poke a few holes in the bottom of the trunk to get that nice exhaust smell.
                          I'm looking forward to seeing this!
                          -Alex
                            Update: Have not tried it myself but thinking about it.
                            Description Item # SPM13930222119 Model # TJ259854
                            We have been providing unique problem solving products for many years from industry leading manufactures using the best 12v auto accessoriesavailable. We maintain a large inventory of parts we sell. Our goal is to have your parts in stock ready for shipment. Our power trunk lock/unlock kit is one of our best and most popular trunk release kit in the industry for Our powerful solenoid and electronics will convert any manual latch on just about any trunk or hatch to a power latching system. 1982 - 1991 e30 BMW Heavy duty power solenoid 11 pound (rated pull) solenoid motor, Push button" (momentary) switch Wiring harness Solenoid 11lbs Length 3.75 Width 1.5 Cable 17 Hardware and brackets for installation Ideal For All Trunk, Hatches, Rear Glass Works With Any Alarm For Remote Operation Limited Lifetime Warranty
                            Added on May 22, 2016
                              That is just a generic kit available in most auto part stores nothing specific
                              Here is one from ebay- http://www.ebay.com/itm/New-Trunk-Re...kAAOSwf05XOxxC
                              My M20 Frankenbuild(s)
                              4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
