Anyone know how to remove the Lock Cylinder from door?
  • synergy141
    • 113
    Just a quick question... I'm prepping my E30 M3 for paint and I'm trying to figure out how to remove this lock cylinder from the door. I've searched and cannot find the answer. Can you guys give me some tips?
    Thanks!
  • lbreevesii
    • Aug 2009
    • 412
    1. open door
    2. remove interior door panel
    3. peel back moisture barrier
    4. use pliers to remove U shaped retainer from lock cylinder
    5. wiggle lock cylinder out of double lock switch plate and remove from door
    installation is reverse of removal, but may take an extra set of hands.
    I don't always wreck cars, but when I do I wreck them into trees.
    91' 318is S50 swap - The Black Widow
    • dogsbark26
      • Nov 2008
      • 533
      Here is a picture of the U-shaped retainer.
      • e30s50dan
        • Nov 2008
        • 2076
        This was useful ....thanks!!
        NASA
        BMWCCA member
        PCA member 25yrs
        1991 318IS slick top
        1997 M3 sedan
        2001 325CI DD
        “whoever turns the wheel the least, wins"
        • mjimport
          • Jan 2010
          • 418
          Need some help, Ive been trying to get that u shaped retainer out for half an hour, there doesn't seem to be any good angle and nothing to really grab onto with pliers.
          I'm at a point where if I put any more force to it I'm going to puncture a hole through my door!
          Any other tricks you all have?
          • mjimport
            • Jan 2010
            • 418
            Ok so I figured out that my locks have heaters which are permanently fastened to the retainer clip. I did not realize that was designed that way. Finally got it out.
