hood wont close all the way
  • mike991
    • Jul 2011
    • 71
    for some reason a small part of my hood never goes down and it bugs me alot, if anybody knows anything why please post a reply id really appreciate it,here are some pics
  • bmwguy325is
    • May 2011
    • 1263
    sit on it harder lol
    It needs adjusted. You do so at the hinge at the front.
    sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
    The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
    • Ceeker
      • Sep 2009
      • 2821
      yeah, that's it...good way to bend the hood.. :-) check the rubber stoppers on either side on the rad support you can finger turn them down or up. try those first.
      • mike991
        • Jul 2011
        • 71
        ill give it a try,any other ideas?
        • ///digitalme
          • Dec 2009
          • 2088
          It needs to be adjusted. It takes forever to get it right. You need a Friend to help you.
          • mike991
            • Jul 2011
            • 71
            how do you adjust it? from the front or the back of the hood?
            • ///digitalme
              • Dec 2009
              • 2088
              In the front by the kidney grill It's a pain in the ass you have to loosen the bolts and press it down from.the side It's sticking out and tighten it and re do it until It's aligned to your liking
              • mike991
                • Jul 2011
                • 71
                thanks ill give it a try soon :D
                • timninja
                  • Feb 2011
                  • 302
                  I had the same issue,what I did is I lossened the hardware then just snugged them down just enough to hold the hood then tweaked the hood so that it would close properly then when it did so I used a 1/4" ratchet and tightened them down to keep the hoods adjustment.i used a 1/4" so I didnt break the bolts.i dono if this helps but good luck
