help me figure out what bumper this is for my e30.
  • hammertime
    • Jul 2012
    • 55
    I recieved a front and rear euro bumper from the PO, and the front fits, yet sags a little bit. But the rear bumper seems to be too long. Everything sits flush, but one side extends past the actual body line of the car. There is no part number, no stamps at all on it. Any clues?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Looks like your brackets are bent, or the rear holes drilled on your car aren't centered.
    • agent
      Vice Grand Pubaa
      • 7960
      Yep, having just helped a friend do a rear Euro bumper install, it looks like that one (or the holes as FK said) is just poorly aligned.
      Originally posted by kronus
      • hammertime
        • Jul 2012
        • 55
        So how do I go about aligning this? I feel like if I shift the bumper to the left a bit, there will still be a gap, the bumper will no longer hug the body.
        • bmwguy325is
          • May 2011
          • 1263
          Take a large mallet to the side that sticks out hit over and over........
          Go driftting and tap that corner on the wall........
          Maybe loosen the mounting bolts and see if you can adjust them....
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • Farbin Kaiber
            Lil' Puppet
            • 29502
            There should be an equal gap on both sides, the bumper shouldn't hide under the lip of the body.
            • hammertime
              • Jul 2012
              • 55
              I might just clean them up and sell them for plastics.
              Sent from my Droid using Tapatalk 2
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                You'll have to cut and do bodywork on the rear bumper to run plastics.
                • agent
                  Vice Grand Pubaa
                  • 7960
                  Agreed - it's too tight against the driver side. As long as the all the new holes were drilled in the right places, the rear mounts were installed correctly and the correct OEM hardware was used, there should be some ability to adjust it.
