What paint to use on ABS plastic? Dupli-color paint matching to Schwarz?
  • seven-57
    • Apr 2012
    • 255
    I'm trying to save myself a couple dollars by painting my front and rear valences myself. I have an 87 325e and I hear that Dupli-color black paint matches Schwarz really well. I was wondering if any of you guys had any experience doing this?
    The front valence I'm painting is an early model 325is front valence. The rear valence I'm painting is a Zender rear valence.
    (Ignore the late model IS valence below it. I'm painting the Bronzit one.)
    So I plan on sanding them down lightly just to get them prepped and ready. Dupli-color makes a sealing primer and a sanding primer from what I've found and I'm not sure which to use. I think I also saw a self-etching primer?
    Any advice at all would be awesome!
  • bmw325csi
    • May 2007
    • 4045
    Just get a automotive clear coat with a good spray pattern tip. Solid black is a easy Color to match. Only a highly trained eye would he able to tell the difference and even then its tough.
    The clearcoat you use should be made for automotive spot repairs and you should lay on 2 nice even coats. Let me find a link to a good clear for you, brb.
    harry/harout
    • bmw325csi
      • May 2007
      • 4045
      High-Gloss Clear Coat Achieve that perfect glossy finish coupled with wonderful UV resistance and a lasting performance with the U-Pol Clear #1 - High-Gloss Clear Coat - UP0796. This ready-to-use automotive clear coat helps improve the gloss on coated surfaces with its immensely shiny finish. It is well-suited for spot repairs and performs exceptionally well on the current 2K clear coating. Clear #1 is a 1K coat in an aerosol and is a wonderful SMART repair tool with a clear finish. Boasting exceptional quality, this U-POL clear coat paint has a wonderful build and shows compatibility on water-based base coats. Providing brilliant sheen and exceptional image depth, this high-gloss clear spray paint stays performing for long. Being isocyanate free, this aerosol clear coat is absolutely safe for use and does not pose any environmental hazards. It dries fast and restores appearance and performance on finished surfaces. The clog-free aerosol performs well and gives a finish of spray gun quality. If you're keen to know how it works, here's a quick look. Clean and degrease the surface of any buildup so that Clear #1 can give you best results. You may need to use an abrasive on solid colored coatings. In case you want to coat solvent-based basecoats with this clear coat, then you can apply it within 20 minutes of base coat application. Shake the aerosol clear coat can properly before use for at least 2 minutes. Apply 1-2 light even coats and let the first coat stand for 5 to 10 minutes before you apply the second one. While it is ideal to leave it to dry for 30 minutes, the drying time may vary with film thickness, temperature and humidity. Looking to restore a look as good as new on the fittings in your automobile? Just a few even sprays on them and they will radiate a gloss more than ever before. The U-Pol UP0796 Clear #1 high-gloss clear coat auto paint is your answer to an easy to use quick fix for achieving exceptional sheen and image depth. Key Features of the U-Pol Clear #1 - High-Gloss Clear Coat - UP0796: Exceptional Gloss: on treated surfaces and they offer good UV resistance Durable Performance: since the coating lasts long and adds aesthetic value too Clog-Free Aerosol: ensures optimum performance by giving a spray gun finish 1K Clear Coat: gives the quality of 2K performance Quick Drying: reduces time between handling Great Image Depth: makes it right for spot repairs WARNING: Cancer and Reproductive Harm -  www.P65Warnings.ca.gov. Free shipping applies to the 48 continental states only.
      This is my favorite.
      harry/harout
      • seven-57
        • Apr 2012
        • 255
        Thanks so much! How many cans do you think I'll need to get two layers for both the front and rear valences?
        • bmw325csi
          • May 2007
          • 4045
          To be safe I would say 2 cans of paint and one clear. The clear I linked is bigger than your average aresol can. Its about 1 and a half cans so one will be plenty. I only needed one when I painted my valance, bumper and is lip, I still had half a can left.
          harry/harout
          • bmw325csi
            • May 2007
            • 4045
            Results
            harry/harout
            • seven-57
              • Apr 2012
              • 255
              Looks awesome! Did you paint any part of that with Dupli-color white or did you just clear coat your original Alpine White paint?
              • bmw325csi
                • May 2007
                • 4045
                Paint matched spray can. White is tricky to match but black is black. When I was at the body shop I would just use jet black for all the solid black car that came in. Good luck.
                harry/harout
                • seven-57
                  • Apr 2012
                  • 255
                  Thanks!
                  • grays
                    • 1343
                    dont forget to buy bulldog flex promoter
