Rust Repair DO IT YOURSELF needed
  • bigdrick323
    • Feb 2012
    • 616
    I've got some nice rusted areas around my car. Anyone have a good diy on fixing? As an example:
    Sent from my HTC One V using Tapatalk 2
    sigpicMy Project!
    Official North Texas Bimmers Club E30 Representative
    www.BimmerAlliance.net
    "If you have questions about events or need help in the DFW area don't be afraid to contact me."
  • MaxBell
    • 1390
    Ok, so you first should decide if you're welding. (which for weird shapes, angles and bends is basically the only way)
    Then look up some welding websites or other builds in here. (ie. M3 minor rust repair, which is stickied up there)
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    • bigdrick323
      • Feb 2012
      • 616
      Going by pep boys to pick up some rust removal spray, then wipe with alcohol, sand, wipe and then wait for doing paint I guess...I saw some of the other threads but I guess I want something in steps using home products or items from local stores.
      sigpicMy Project!
      • idickers
        • Sep 2011
        • 92
        You could look here for some generic rust repair tips: http://www.bmw2002faq.com/component/...opic/t,370990/
        • vert_this
          • Feb 2012
          • 395
          plenty of project threads here that have cut out tons of rusted metal.
          • bigdrick323
            • Feb 2012
            • 616
            I am hoping to fix without cutting and welding. I just want to stop it where it is and paint it.
            I am away from my computer, being lazy!
            sigpicMy Project!
            • AndrewBird
              The Mad Scientist
              • 11892
              If the rust is just surface rust and hasn't rotted through, you can fix it without welding. Start out with a wire wheel and clean all the rust off, plus another 1" of the paint around the rust spot. I would then treat the area with some kind of rust inhibitor, something like this:
              http://www.lowes.com/pd_117792-133-0...%7C1&facetInfo
              The instructions will likely say that you don't have to wire wheel the area first, but the more you get rid of with the wheel, the less that stuff has to do.
              From here, it's just a matter of primer, block sanding and paint. Filler primer would be your best bet to fill any small pitting from the rust. Use as little as possible, putting on a few coats, sanding in between coats.
              You can get factory color matched paint in a spray can from www.paintscratch.com.
              • bigdrick323
                • Feb 2012
                • 616
                Perfect, thank you!
                sigpicMy Project!
                • bigdrick323
                  • Feb 2012
                  • 616
                  Ok, worse than I thought, the holes are non-existent, what can I put on there (not welding) that I can put screws in????
                  sigpicMy Project!
