Wrap it before you tap it (Pic heavy)
    very nice! lot of hard work I am sure. :)
    Leo
      It looks like all the glass has stayed in the car throughout the entire process. Is that the case?
      Originally posted by kronus
        Yeah all the glass stayed in. With a wrap there isn't a need to take it out. It could help I guess by having the edge of the vinyl under the seals but then when its time to strip it you would have to pull all the glass out again. I plan on sticking with this color for a while and then changing it up a few years down the road.
          Did you tuck any of the vinyl under the edges of the window seals, or just butt up against them really closely?
            i pushed it into the seals the best I could and then cut them with an exacto knife right on the edge of the seal. Its about the best you can do. If you are really good you can cut the vinyl just up on the seal and then tuck it after you cut it.
              Removing an E30 front and rear windscreen is a 20 min job.
              I'll be removing mine when I cover mine in vinyl.
              BTW, the colour looks
              If you have bought items from me, please leave feedback below.
              If you are a BUYER, Check My Feedback.:up:
              http://www.r3vlimited.com/board/showthread.php?t=183860
              Check out my Euro Build Thread
              http://www.r3vlimited.com/board/showthread.php?t=215557
                True, but (re)installing them is not nearly as simple.
                  20 minutes getting it back in and another 10 minutes for the locking strip.
                  But my point wasn't the time but why cut corners after going through the trouble of doing a good job.
                    Using brand new rubber and a brand new lock strip? That's quite impressive! The professional glass installer I used took well over an hour for each, and gouged my freshly painted trunk in the process (documented in Klaus' build thread).
                      I don't really consider it cutting corners. Professional wrappers wouldn't be putting it under your seals. The would just trim it right up to the seal like I am doing. Wraps are not designed to be permanent.
                        If you have the right tools, and have done a few of these, then you should be able to cover that time no proble,
                        I wasn't saying that "You Cut corners", what I meant was it's your car, and to do it the way I would.
                        Having the "Professionals" doing it??
                        I've seen work here done by the "Professional", and it is totally shocking.
                        YOurs looks a lot better.:D
                          Yeah professional is a broad term I guess. There is a company here in town of "professional" wrappers and I think they have a 5 year old in the back designing them and a dog installing them.
                            Its pretty much done. I still need to do the rear bumper and paint/install all the trm
                              love it. how much material did you use? what was the cost. PM ME
                                about 12 yards. $333 dollars for 15 yards of vinyl wholesale
