Anyone have suggestions on stripping paint off a wing that is rubber without losing any details or damaging it? I do not want to sand.
Stripping paint off wing
Tags: None
Brake Fluid, or Easy off. Try a test spot 1st
edit: rubber? sure it's not plastic? Not sure how that would work on rubber -
its rubber. same material as the rear section of mtech 1 wing. the thing is it has a wrinkle texture to it. it is covered with paint. sections started to peel of but other sectionsseem to be harder. when i googled i saw brake fluid dot 3, fairy power spray (only in uk), heavy decreaser and dettol. all has been used on plastic.Comment
If its starting to peel off, try seeing what a good strong pressure wash will do. may be enough to get it to lift off. I've never seen an mtech kit so can't comment on the material.Comment
Sand it down till its smooth with 320-400 grit, make sure you've gotten through any clear coat there is. Tack it, primer, light sand with 400 grit, tack it again, then paint it desired color, light sand for imperfections, tack, shoot one last layer of color followed by clear. Did this with my spoiler and other parts.. The prep work is the most important part, spend time on this; It will dictate your finished result. It'll look factory if you do it with care and proper execution.Comment
Easy Off will work without harming plastic/rubber. The downside is it only takes off one layer at a time so it's tedious but it works.
Avoid any kind of brake fluid - while it will strip the paint, it will also make some plastic/rubber extremely brittle.
If you're going to re-paint, take it to a shop that knows what adhesion promoters are and how to use them and let them do it.Comment
