Plasti-dip removal
  • IRON-E
    • 16548
    Plasti-dip removal
    What is the best method of removal?
    I have used a power washer for most of the larger areas but I'm having dificulty removing this stuff from the hidden corners an what not.
    I've also heard that on wheels, you can use brake fluid , leave over night and it'll break up the paint into a slimy/rubbery goo.
    What else can I use?
    @IRON-E30 aka Edwin:D
  • ky0u
    • Dec 2012
    • 808
    No luck just pulling? Goo gone takes it off pretty well in the places where its stubborn
    Web Designer / Front End Developer
    My Portfolio & Website
    IG: @w_illriderz
    • FLG
      • Sep 2011
      • 3165
      My gf sprayed her 240 (before we met, thankfully) and wanted to remove it, we sprayed the whole car with goo gone, let it sit, then pressure washed the whole thing off. Make a fucking mess but a lot easier then pealing it piece by piece, never again.
      -Build http://www.r3vlimited.com/board/showthread.php?t=295277
      • marshallnoise
        • Sep 2013
        • 3148
        Goof-off and steel wool. That plastic-dip is evil btw.
        Si vis pacem, para bellum.
        New Hawtness: 1995 540i/6 Claptrap
        Defunct too: Cirrusblau m30 Project
        Defunct (sold): Alta Vista
        79 Bronco SHTF Build
        • TheTacoMan
          • Nov 2011
          • 2308
          Many hours it took to get a plasti dipped e30 cleanish.
          • Exodus_2pt0
            • 5943
            I love this.
            I tried to warn people that it is a bitch to remove after a while.....
            No E30 Club
            • marshallnoise
              • Sep 2013
              • 3148
              Originally posted by Exodus_2pt0
              I love this.
              This fender is what happens when a fender has been plastic-dipped for a long time.
              • Exodus_2pt0
                • 5943
                Oh, and if your wheels are painted, I don't recommend putting brake fluid on them.
                If they are painted with automotive grade paint, my suggestion is to hit it with non chlorinated brake clean, and hit it with a pressure washer.
                In my experience with PD emblems, brake clean makes it pliable again and easier to remove. Never did an entire car because of my issues with smaller items after a year.
                No E30 Club
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  hold up, steel wool? Yikes
                  2014 Alpine White 335i MSport
                  (Daily Driver)
                  Full Mperformance Aero
                  KW V2 Coilovers
                  VRSF Catless Downpipes
                  • lillyputtt12
                    • Apr 2014
                    • 1
                    Hi Friend,
                    Welcome on this fantastic Forum.I hope,You will be OK.
                    I don't have any idea about your question but if you want
                    to learn about classifed websites Click on the link
                    Classified Website
