Just wondering what R3v thinks the best way to do an antenna delete the right way would be? I was thinking cut and weld some sheet metal to patch the hole and then smooth it out with body filler. Is this a good idea? I just think the plastic caps are tacky.
Doing antenna delete the right way???
Tags: None -
I've always patched it with metal, ground the welds down, then used as little filler as possible.
I always though that since there is that little "tang" right in the way under there that I would use a small chunk of fender from a wrecked E30.Comment
I did this. Came out really nice.Comment
