e30 advice on front licence plate mounting?
  • cirrusblue
    • Oct 2014
    • 433
    Hello,
    1987 325, pre facelift... licence plate question?
    I live in a state that requires a front licence plate, and I want to mount a permanent licence plate bracket on the bumper. The car used to have one, but now has been in FL for years and it seems there is a plastic part about 1 foot long over the portion of the metal bumper where a mounting bracket prob. used to be when the car was a northern car
    Any advice on how I can tap the screws into the pre-facelift bumper?
    Yes, I know some folks won't like this idea, but I just want to permanently mount the bracket. I'm ok with it. The car is 87 325.
    I just don't want to start testing screw holes and find out I can't tap it, or make a mess of it.
    Any thoughts appreciated.
  • cirrusblue
    • Oct 2014
    • 433
    under or on
    I saw something like this which looked interesting, but maybe i"m over thinking it...
    I did buy a standard black plastic mounting online and it's on the way.
      • 37832
      Why not just buy the OEM BMW part that goes there? It's under $25 new. Part number 51181971266
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • Reichart12
        • Aug 2012
        • 2163
        Or the original piece from a junkyard for about $5-10. If you are switching to a oem piece with bracket you could probably sell the filler piece you have to make back your couple dollars.
        Instagram: Reichart12
        • cirrusblue
          • Oct 2014
          • 433
          Thanks for the part number...
          I didn't realize there was a part for this! Thank you.
          The issue is I can't figure out how to get the bumper strip that's currently inserted in there "out"... I kind of tried to wedge it out but I wasn't sure if it was going to break. I coudln't get my hand behind it. Any advice on getting the strip out would be really apprec.
          Thank you!
          • Reichart12
            • Aug 2012
            • 2163
            There should be nuts/bolts holding it on. 2 I believe. The metal bumper will only be hold onto the bumper shocks by a couple bolts. Undo that, pull the bumper off and check out the back of the bumper for whats holding the filler piece on.
            • cirrusblue
              • Oct 2014
              • 433
              Bumper strip... thank you!
              that make sense, I'll do that. I could feel 2 large wing nuts behind the strip but it was impossible to reach while attached. I'll take a look a this. Thank you you
              • Reichart12
                • Aug 2012
                • 2163
                Yup that sounds like what youre looking for. Post back if you need any other help.
                • Steve Corbett
                  • Jul 2012
                  • 449
                  I have the bracket you need if you want to swap me the filler piece.
                  Steve Corbett
                  1983 528E Scrapped
                  1983 528E Sold
                  1984 745I
                  1984 325E - Sold
                  1989 325I Bronzit-Sold
                  1989 325I Zinno
                  1988 635CSI
