Late Model Front Bumper Bolt stuck, Help!
  • Silver Wagon
    • Jun 2014
    • 184
    so i started to pull out the 2 torx bolts that hold on my plastic bumper. one came out just fine. the other just spins. it unscrewed for a little bit, it was tough, but still turned. now its just spinning. i feel the captured nut in the bumper has broken loose and is spinning. how can i access that nut so i can get my bumper off?
    drilling the head of the bolt won't work as its still captured by the bumper strut.
    can i disassemble the plastic bumper while its still on the car?
    please help, i want to get my new front valance on.
  • Silver Wagon
    • Jun 2014
    • 184
    anyone?!
    • gotaloveRWD
      • Jul 2011
      • 708
      I think you can get to the bolts holding on the bumper shocks can't you?
      I don't remember it's been a long time since I've had plastic bumpers
      IG- nv_e30
      • Mr. Tasty
        • Jul 2011
        • 3421
        seriously, just remove the 4 (2 each side) 13mm bolts that hold the shocks to the car.
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • Silver Wagon
          • Jun 2014
          • 184
          i don't think i can get to them, the bumper is covering them up. i will check it out though.
          • Silver Wagon
            • Jun 2014
            • 184
            there's no way i can get to the bumper shock bolts. the bumper is tight against the body.
            any other ideas?
            • MA325is88TWO
              • Jan 2014
              • 16
              Get one of those extractor sockets that grabs the OUTSIDE diameter of the bolt head. Or one of those sockets that removes old fashioned lug nut wheel locks.
              Or start drilling.
              Welcome to Chicopee MA!!
              • Silver Wagon
                • Jun 2014
                • 184
                the bolt isn't seized, the captured nut, or whatever the bolt threads into inside the bumper, has broken loose and spins with the bolt. i need a way to hold onto it, or stop it from spinning, so i can unscrew the bolt.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  The plastic bumper skin will come off and give you more access. I believe it just snaps into place into the bumper reinforcement. Search for how to remove it.
                  • profbooty
                    • 308
                    Pull the bumper cover off, its clipped on along the edges.
                    Underneath you will find 3 LARGE torx screws that hold on a metal plate to which the bumper shock attaches. Remove these and the bumper will come off.
                    You can then replace the bumper shock if needed. You will likely need a new metal plate that also afixes to the bumper shock. These pieces together run under 10 bucks at the dealer, locate a new bumper shock as well. I had the same issue with a bumper bolt that would not turn and the head became stripped.
                    Be sure to dab some neverseize on the bolts when you reinstall them.
                    • Silver Wagon
                      • Jun 2014
                      • 184
                      ok, thanks guys. i will give it a try tomorrow, weather permitting.
                      i tried to search how to remove the skin but didn't get very far.
                      i have new shocks. i was doing this primarily to replace my valance.
                      if anyone can find a good DIY of removing the skin without taking the bumper off that would be great. in the meantime i will do some more searching.
                      • profbooty
                        • 308
                        Feel under the bottom of the bumper cover. You will feel a number of plastic tabs which run about every 6" or so along the entire bumper cover.. You have to either push up or down on them to release them.
                        Wish I had known about them before i damaged my lightly damaged bumper cover into a mostly unusable bumper cover.
                        • Silver Wagon
                          • Jun 2014
                          • 184
                          do i need to remove the trim pieces also, or just those tabs?
                          i can't find any good pics of what parts to take off to get the skin off.
                          • profbooty
                            • 308
                            No you shouldnt need to remove the trim (I made this mistake). The little plastic bits from the cover stick out behind the bumper just a little bit. You should be able to feel them from underneath.
                            • Silver Wagon
                              • Jun 2014
                              • 184
                              i got it! as it turned out, it wasn't the captured nut spinning. the shaft of the bolt was so caked with rust from either the shock mount rusting or the bolt itself that i had to pry it out. i managed to get a pick behind the bolt head to create some downward pressure while turning the bolt. i got it out far enough to get some pliers on it and just pulled it out the rest of the way.
                              thanks for all the reply's guys. finally got my valance replaced.
