Fender Damage: What to do?
  • blacktyevent
    • Jan 2015
    • 76
    What can i do about this? I am open to hearing all options from rattle-canning it to a full-blown chassis repaint. It is warped and will need some some kind of body work.
    I just bought the car and thought i would have a budget for body/paint which has slowly evaporated as i overhauled the engine, redyed the interior, and upgraded the audio system.
    All constructive advice is welcome.
    www.tycacek.com
    Currently Driving:
    1986 325e- Custom Nebula Purple Dip, 5MT, Lukebox. A Perfect DD. ;)
  • Artful Dodger
    • May 2008
    • 156
    I think to fix it, it would need to be sanded down, worked with a puller/hammer to get dents and wrinkles out, slap on some body filler, sand it smooth to best of ability, use a high build primer like featherfill, wet sand til happy, color match paint, buff. the color match would be done on probably most of that rear quarter. use the body line ans pinstripe to break up the repair from the old paint.
    This should work and you could do it your self if you have patience. body work and paint take a lot of patience.
    • Artful Dodger
      • May 2008
      • 156
      here are some pictures of what I did to fix my fenders after rolling/stretching them to fit my larger tires...
      • Navarone
        • Jun 2014
        • 935
        Just paint pen it to knock the ass off and when you have the money get it professionally fixed.
        • Artful Dodger
          • May 2008
          • 156
          or that, you could do that too.
          • blacktyevent
            • Jan 2015
            • 76
            Great advice guys. Thanks!
            www.tycacek.com
            Currently Driving:
            • Navarone
              • Jun 2014
              • 935
              Sure thing. The paint pen is just eye wash, it takes away the big scar that says "look at me!" It's not going to be great, but at a glance you probably won't even see that it's touched up.
              You can probably find gloss black touch up paint at most part stores too.
              • AndrewBird
                The Mad Scientist
                • 11898
                Since it's black, rather than use a paint pen, get a can of gloss black spray paint, mask around the damaged area and shoot it. Might scuff it up with a scotchbrite first so the paint sticks better. Josh (Jand3rson) did his front lip with Duplicolor and it matched the stock black perfectly.
                • Navarone
                  • Jun 2014
                  • 935
                  Hrm, wouldn't that result in overspray, blending and tape lines?
