repainting/ "re-blackening" the plastic D-board center bumper trim
  • 87-325ic
    • Apr 2006
    • 1198
    should i go with that "restore the black trim" stuff they sell, i think Bondo makes it..
    or should i sand it lightly and spray it black with some good trim paint (any brand/paint suggestions)
    gonna be tucking soon, and i should do this first i believe..
    Thanks.
  • browntown
    • Jun 2004
    • 3524
    VHT is popular around here.
    • Sean
      • 5793
      You mean SEM Trim Paint? VHT is high temp paint. Not sure why you'd want that on trim. ;)
      - Sean Hayes
      • browntown
        • Jun 2004
        • 3524
        you're right, momentary lapse.
        • StereoInstaller1
          GAS
          • 22679
          Get a gallon of "Wax and Grease Remover" from any body shop supply store, and some "3M Sctoch-Brite" pads from anywhere...gently scrub with the W&G stuff...it evaporates quickly, so be fast. Do a final wipe with W&GR, using a fresh, clean cloth, wiping in ONE DIRECTION ONLY (so you don't track filth over the clean) Quickly mask and spray.
          SEM is the roxorz, but Dupli-Color (with the available "Adhesion Promotor" works well too) bumper trim spray is cool, and a perfect color.
          Don't be too dissapointed if this becomes a yearly habit.
          If you plan on painting the aluminum bumper too, that same tactic works OK, but I use a 3M aluminum surface prep tool, on a die grinder, with an air compressor...they last quite a while.
          GL, HTH,
          Luke
          Closing SOON!
          Thanks for 10 years of fun!
          • 87-325ic
            • Apr 2006
            • 1198
            ok, thanks. so the wax and grease remover cleans it up nice, and evaporates quick,
            as to leave a nicely clean surface in which to paint...
            should i take it off the car first? i mean, black specked is not my look..
            what exactly is SEM paint? is it a type? or a brand..
            • cactusjacks1
              • Sep 2004
              • 1216
              It's a brand - the color or label on the can is "Trim Black - 39143"
              [I
              • 87-325ic
                • Apr 2006
                • 1198
                ok thanks...
                wheres the best place to pick it up? im in NC.. i didnt see any at advanced auto, does walmart or Sears have it?
                • StereoInstaller1
                  GAS
                  • 22679
                  Look up "Automotive Upholstery Supply" in the phone book.
                  Closing SOON!
                  • delphini
                    • Apr 2006
                    • 680
                    DUDE, try looking at the llocal CARQUEST the one here in S.C. has an excellent paint section that will custom mix ANY color you want ,PPG paint.
                    :pimp:
                      • 37832
                      Aside from replacing the trim, SEM is your best bet.
                      I loves me my new bumper trim. :)
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • nismoman
                        • Jul 2006
                        • 246
                        where can you buy new trim from? does bmw still carry that shit?
                        1985 s50b30, 91 front and rear valence, e30 m3 suspension, advance design coilovers, GC camber caster plates full solid bushings alla round, adjustable rear arms, ireland sways front and back, ireland big brake kit front and back , team dynamics wheels, 24lb injectore ltw fly, intake , headers, exhaust, so forth so on......
                        • 325iCabrio
                          • Jun 2006
                          • 485
                          BavAuto carries it. I think Pelican Parts does too.
                          1988 325ic Automatic
                          • Jand3rson
                            • 37587
                            When I painted my bumper trim, I simply cleaned all of it with hot soap and water, then with acetone. I then put about 4-5 coats of SEM on them and let dry for 24 hours. It's hard as a rock, and I've made 3 trips to Portland (160 miles), and not a chip or scratch to be found.
