water/moisture in my trunk and undercoating falling off.
  • jonnywadster
    • Mar 2015
    • 58
    I'll add pics to this post soon, I took them but they are on my phone.
    The undercoating under the door is starting to split right in the middle at the body seam.
    What's the best affordable way to take care of this issue, I don't have the funds for a paint job right now.
    Also my dang trunk smells like a wet dog all of a sudden. The seal looks good on the trunk I ordered a new one just in case.
    could it be my rear window seal? Looks kinda crappy.
    Thanks guys. really don't want to get rid of this car and it's turned into my daily driver thanks to everyone on this forum.:stupid:
  • AndrewBird
    The Mad Scientist
    • 11898
    As far as the trunk goes, check to make sure your sunroof drains are connected. They plug into vents in the side of the trunk on each side. Also check your tail light seals as water can get in there as well.
    The trunk seal generally won't leak unless you are parked facing downhill and water can pool at the front edge and corners of the trunk, causing the water to go above the seal. Otherwise the water just drains around and down the sides.
    • jonnywadster
      • Mar 2015
      • 58
      tail light gaskets
      turned out to be my old and crispy tail light gaskets.\
