Painting Bay with motor still in.
  • niccuhles
    • Jan 2016
    • 129
    Anyone have a pics of before, in progress and after pics? I really dont want to pull my motor just to paint the bay so kinda wanna see how it could be done without...
  • spike68
    • Apr 2009
    • 1185
    There are a lot of spaces that are just too tight to spray with the engine in place. It will probably wind up looking worse than it did or just clearly inconsistent. With that said unless youre planning on just painting the strut housings or something near the top its not really doable. I say do it right and pull the engine if you want to paint it that bad. Although most of the people who paint their bay just wind up doing because theyre already pulling the motor for a swap or for some other reason.
    I don't even own this car anymore, but I'm too lazy to change the picture.
    • The Real e30
      • Sep 2015
      • 73
      I've done it... Not that difficult just depends on what result you want is how much time you spend. I took off all the things around the strut towers and front end including radiator then wrapped/taped engine and everything else you don't want paint on. Get a smaller gun if you want to get in the tighter spots but really its just prep and technique and you can make it look as if engine was removed. Hope this helps!
      • sampayne
        • Apr 2014
        • 396
        Have any pictures?
        Originally posted by 2mAn
        The BMW V6 is the best
        • AndrewBird
          The Mad Scientist
          • 11898
          You'd probably spend the same amount of time masking everything as it would take to just pull the motor. And then you have way more room to prep and work, making that process faster as well.
          • EyExR
            • Jan 2011
            • 959
            Unless it's an iX
            My 325iX DIY Threads:
            Front Wheel Bearing Replacement
            325iX Rear Subframe Bushings and MUCH more w/pics!
            325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
            • The Real e30
              • Sep 2015
              • 73
              I'll see if I can dig up some pics and put them up later tonight.
              Not everyone has an engine hoist, and you would still have to remove all the miscellaneous bits around the engine bay to paint under them. The engine doesn't really interfere with anything if done right, other than the fact that the vertical areas directly left and right of it are at a bad angle and hard to reach. Then again, they are hardly visible and as long as you get some paint down there it will look fine. My original color was bronzit so it doesn't pop out in the areas I couldn't hit. Might be a different story with a red color.
              • The Real e30
                • Sep 2015
                • 73
                • sampayne
                  • Apr 2014
                  • 396
                  Wow, I'm impressed. That came out really nice. Good job!
                  • The Real e30
                    • Sep 2015
                    • 73
                    Thank you! My first time doing any bodywork or painting and I'm happy with the results.
                    Sent from my LG-D851 using Tapatalk
                    • niccuhles
                      • Jan 2016
                      • 129
                      Wow! Looks good. I think I'll try my luck with the motor in!
