Painting Engine Bay - how much paint?
  • badwella
    • 357
    I have to repaint my engine bay again. I found a couple rust bubbles and I was displeased with the initial paint job (rattle can color match).
    My brother is lending me his HVLP system which he uses for painting motorcycles.
    I am only painting the engine bay and a new radiator support (replacing a cheap Korean knockoff with an OEM one). Lachssillber Metallic so it's two stage.
    How much paint do I need? How much clearcoat?
    Thank you
    P.O.S 1989 325is - aka Project Sh*tbox
    Project Shitbox - Restomod and other stuff - soon to be 328is
  • gart
    • Jul 2012
    • 295
    Depends on the mixing ratio but you should be good with a quart of paint if you are putting color on the whole bay. That will likely give you 1.5 quarts sprayable material. Quart of clear should be sufficient also. Mixed that will likely be 1.25-1.5 of sprayable material.
    89 325 cabrio in progress m52tub28 swap
    99 540it
    86 Volvo 240 wagon
    99 Cherokee
    13 Passat
    • badwella
      • 357
      Awesome. I appreciate the help!
