Driver door stay/stop Re enforcement
  • mc625569
    • Apr 2017
    • 125
    Hello,
    The sheet metal in my drivers door that holds the door brake/stop is damaged to the point that the bolt holes won't properly hold the door stop mechanism and support the weight of the door.
    I have no experience with welding/or sheet metal. Are there any pre-fabricated reenforcement plates for this?
    Something like the Porsche kits here
    Is anyone aware of an e30 type product like this?
    Or aside from taking it to a body shop, which in my area will probably be 500 minimum, any ideas on the best way to repair?
    I don't want to find a new door, since I don't want to pay for a repaint.
    -MC
  • AndrewBird
    The Mad Scientist
    • 11898
    This is a common problem in E34s. Perhaps the plates made for those will fit the E30? Either that or make up your own.
    While searching for the E34 plate, I came across a company that makes one for the E30:
    • lukeADE335i
      • Apr 2013
      • 1389
      Nice find! My drivers door has let go completely in that area due to metal fatigue, so I've been driving without the door brake for years. Might have to order one.
      My e30: OEM+ with M30B35
      • mc625569
        • Apr 2017
        • 125
        http://www.bmw-stuff.com/proddetail.asp?prod=drpe30
        Thank yo u! this was what I was looking for.
        I just ordered one. I hope my door panel can be saved, its quite tweaked.
        • mc625569
          • Apr 2017
          • 125
          Update. The Reinforcement plates from Koala motorsports solved my problem.
          For 15 bucks I bolted this into place and voila I was able to install a door brake.
          It is always so satisfying to find an inexpensive purpose built niche product to solve the exact problem you hare having.
          • jtheilbrun
            • Jul 2017
            • 26
            I'm having a similar problem. If I hook up the door brake to the door it makes a very loud popping noise when opening and closing the door. I believe this is because a weld has broken loose inside the car side of the pillar. Any idea if this would fix that as well?
            • mc625569
              • Apr 2017
              • 125
              If you have a bad weld on the car frame vs a torn up door itself, then I can't see how this would help you.
              • jtheilbrun
                • Jul 2017
                • 26
                Thanks for the response, now it makes sense. I kept looking at the pictures and knew I was missing something. And now I realize these go on the door not the frame side!
