Sunrooof rust bubbles
  • n3nyongmini
    • Jun 2006
    • 593
    On E30's, are the typical sunroof rust bubbles caused by rust forming at the top, under the finish paint, or by rust coming through from underneath?
    IOW, should I 'pop' the bubbles, clean, prime and touch-up the paint, or will I be faced with a small hole clean through the sunroof panel? The two bubbles are about 5mm across at this point and don't seem to be growing, but I see 'em every time I get in my car...
    The car has been in San Antonio for all of it's life/owners (as best CarFax will tell me), so no current, constant contact with road or oceanic salt.
    Thanks - this site is da bomb.
    Derek
    HE>i
    89 335i m30 power, 4hp22 delivery
  • Apex381
    • Mar 2004
    • 740
    My car was a California car most of its life and yet its still rusting on the sunroof panel like yours is. Mine is definitely rusting from the underside up and whenever I open the sunroof rust sifts down into my car like a light snow! I think our best bet would be to just get a new sunroof panel.
    1987 325is - sold
    2001 330i - New DD
    • mtechnik
      • 6156
      I have a small spot prolly round 3/4 inch in diameter & thankfully hasn't increased in size since I bough the car 3 yrs ago. This with wet winter seasons
      • Dex.e30
        • Mar 2007
        • 153
        I also have a few minor rust spots, and was curious about how to mange them. Repaint won’t be until next year likely.
        >>> My E30 For Sale <<< ||| My MCoupe For Sale ||| Miscellaneous Items FS ||| *E30* Items FS |||
        • adept
          • Feb 2006
          • 425
          I usually try not to bother with them. Sucks, but I have a small spot on my sunroof as well.
          • rede30
            • 4697
            yea unless you are going to paint the whole panel dont worry about it. After saying that, it wouldnt be that big of a deal to have the sunroof painted. You could just have a few other things painted at the same time: lips, mirrors, bumpers, whatever you have just to make it worth your time to deal with a paint shop. Also you can search around for used sunroofs that are the same color as yours. I have a mint blue one that i would love to sell to someone who needs it.
            • MikeE30325i
              • 2356
              damn, i am lucky and only have rust on the rear valance right above the muffler tip.
              but dont worry about the rust unless you plan on painting the whole panel.
              • BDSax
                Junkyard King
                • Mar 2006
                • 3594
                when the sunroof starts to rust, its fucked. it starts rusting the metal seems inside and its not worth it to fix. i found a good panel at the junkyard ($30) and got this stuff from eastwood called Rust Encapsulator. I soaked the hell out of the inside of the panel where the metal seems together to help prevent rust. other then that i would suggest keeping your drian holes clean.
                • IDontLikeYou
                  • May 2007
                  • 3
                  Although already pretty much answered, ours is from the inside out. The front lip is almost completely deteriorated inside (driver's side corner), and only bubbles on the outside. A new (or better used) one is on the list of things to do, but it's not leaking, so we are just not worried yet.
                  +1
                  Plain and simple. I don't like you.
                  1987 BMW 325e Sedan :: lavender - HIS
                  1986 BMW 325es :: cinnabar red - HERS
                  • egk2
                    • 2426
                    Yes, when you see rust forming on an e30 sunroof panel, it's a wrap.
                    The feet on the sunroof panels also tend to rust which causes the
                    typical sunroof sag. Buy a new panel.
