e36 front bumper on 85 eta
Tags: None
hmmm for some odd reason it doesn't look bad at all. Do you know if he plans on modifying it to fit somewhat perfect?92 Granite Silver Vert
M60B40 5spd -
Like I said, 30 minutes of work. A little bondo goes a long way. Gotta get it painted better then work out the kinks.Comment
Doesn't look that bad at all. Definately needs some plastic work. How did you mount it...I don't want to hear "Zipties" What kind of reinforcement do you have back there too?:: PNW Crew ::
'87 325 4dr, '74 2002Comment
If you want to do it right the first time and not have to go over it once a month don't use bondo because from the looks of it you will need a big chunk to get that middle section filled in. Even though there is no pressure on the middle, if it were me doing it, I would ask around body shops to see what they will use to fill that in. Fiber glassing it wont be bad, anything that can fill that gap in.92 Granite Silver Vert
M60B40 5spdComment
