My E30 project.
  • EWAustin
    • Sep 2006
    • 234
    #31
    The key to getting the filler perfectly flush is lots of sanding using a block like this
    Painting is a little trickier, you paint the first coat going over the part that needs to be painted, then you reduce the paint 1:1 again and paint a larger area, then reduce it again 1:1 and paint a larger area etc etc etc until you can't see the fade.
    Then you gotta clear coat it.
    Eric Austin
    1990 325i Sterling Silver
    ///M3 CABs | ///M3 strut bearings | Bavarian Autosport springs | UUC Race Shifter | UUC Clutch Stop
    • mops
      • Jan 2006
      • 138
      #32
      that is trully insigfull.
      that sanding block... does it have rubber underside, or firm (like a block of wood) ? should you apply alot of pressure or rater many strokes with less pressure ? circular motion or back and forth ?
      I tried to fill up hole after arieal, but it came out very bad... both paint and filler...
      paint wise, before painting "intermediate" area should you sand it with something like 400 girt or just clean thoroughly and it is ready to paint ?
      • EWAustin
        • Sep 2006
        • 234
        #33
        The block is solid rubber. Firm rubber, but not hard like metal. I use a combination of back and forth and circular motion. Just keep sanding until when you close your eyes and run your the flat of your hand (palm and fingers) over it you can't feel the change between the paint and where the filler is. If it gets too low, let it dry, clean the area. put more filler on and do it again.
        The hole from the antenna should be welded shut before you put filler over it, otherwise it'll crack and fall out very quickly. Filler isn't very strong, and should be used as little as possible.
        Intermediate area should be wet-sanded with 400 grit,
        Eric Austin
        • trent
          #34
          look for DURA-BLOCKS
          that is the best invention in the world for sanding
          • EWAustin
            • Sep 2006
            • 234
            #35
            DURA-BLOCKS look nice, I've never tried one though.
            Personally I like 3M's sanding block; cheap, effective, and teaches you the value of a good DA
            Eric Austin
            • EWAustin
              • Sep 2006
              • 234
              #36
              It's late, I'll write more about these pics later, but here ya go:
              Door off
              Door on
              New Trunk lid
              OEM lip spoiler mounted, tomorrow it comes back off for more sanding. Yes, I know that it looks funny without the bumper there.
              Eric Austin
              • EWAustin
                • Sep 2006
                • 234
                #37
                finally more to see:
                Tuesday... Paint
                Eric Austin
                • xLibelle
                  • Aug 2004
                  • 2673
                  #38
                  little bit of a drip there. anything special going under the hood?
                  • EWAustin
                    • Sep 2006
                    • 234
                    #39
                    Lotof a drip, turns out the quickie-lube place I took it to stripped the drain plug. They'll be paying for a new drain pan shortly.
                    Under the hood is anti-special for now (230k mile M20b25), but it'll probably be sold before I get to that :-(
                    Eric Austin
                    • EWAustin
                      • Sep 2006
                      • 234
                      #40
                      Spraying the rubberized undercoating on the rocker panels:
                      All done:
                      Wait a minute, where did my car go?
                      Oh here it is, about to go into the paint booth!
                      Eric Austin
                      • etajohn
                        • May 2005
                        • 79
                        #41
                        Whaaaa!!!!! The suspence! Looking good so far!
                        • EWAustin
                          • Sep 2006
                          • 234
                          #42
                          So Close!!!
                          Sprayed the last coat of primer today. This one doesn't get sanded.
                          Tomorrow morning I mix the paint, dust the car, and spray the car.
                          As usual, the rest of my pics can be seen here: http://www.flickr.com/photos/ewausti...7594503771710/
                          Eric Austin
                          • Rennsport
                            • 2139
                            #43
                            im sooo jealous of your skills, my car needs a good bit of body work and a whole bunch of paint, but painting is much to tedious for me, guess ill just keep saving my pennies (little copper coins you pervs, not my penis)
                            m106 1990 e30
                            e36 daily
                            e32 cruiser
                            • Jean
                              • 18228
                              #44
                              That's a lot of patience man! Thumbs up!
                              • EWAustin
                                • Sep 2006
                                • 234
                                #45
                                Whoa, the fumes :p
                                Spraying:
                                Take that! Evil white hood!
                                Also, it gets hot in the booth. 90+ degrees from start to finish:
                                Tomorrow I spray the clear coat, then reassemble it next week.
                                Many Thanks to my good friend Sam for taking time out of his day to photograph mine.
                                Eric Austin
