88+ Plastic bumper question
  • bwh13
    • Jan 2007
    • 437
    Has anyone been able to get the mounting parts kits for the front and rear lately? #51129059109 and 51129059108
  • FredK
    • 14762
    What's in these kits?
    • Flyingbricke30
      • Apr 2009
      • 46
      Yeah, working on refinishing some plastics for my Diving board conversion + would like to order these kits, But I'm not sure what they contain.
      Anyone know?
      • be34st
        • 1277
        +1 for info on this "kit" if it exists
        07 Designio E63 AMG / 1984 318i (M20Swapped)
        • ethree
          • Aug 2007
          • 1213
          Why not just pull all the brackets out of the junkyard when you buy your plastic bumpers?
          • ethree
            • Aug 2007
            • 1213
            • cepa318is
              • Mar 2008
              • 228
              Front Mounting Set part #51 11 9 059 108
              link: http://bmwfans.info/parts/catalog/51119059108/#set
              Rear Mounting Set part #51 12 9 059 109
              link: http://bmwfans.info/parts/catalog/51129059109/#set
              Currently the Front set is on national backorder. I am waiting for the front set to come from Germany. Just an FYI for you all
              • FredK
                • 14762
                Oh, nice! The links lead to the kit contents, which I'll archive here on r3v as well.
                I sourced a front and rear bumper shock kit with mounting hardware from someone on r3v, and it included just enough hardware to get my bumpers mounted again. I think the fit kits also include a lot of internal hardware, like the plastic hardware that secures the bumper cover to the fiberglass bumper carrier.
                I needed, in addition to the shocks,
                4 bumper shock bolts and washers
                4 M8 bolts to mount shocks to front of car
                4 M8 nuts with funky washer to secure rear shocks to the car
                Front brackets (L/R)
                4 screws to secure front brackets, and some miscellaneous washers to space the bumper away from the body (I'm not sure if all E30s have the same washers, or if it's done by eye at the factory)
                Rear brackets (2)
                4 M6 nuts to secure the rear brackets to the chassis
                The fit kits include a lot more stuff:
                Front
                07 11 9 931 699 Flat Washer 13 2
                07 12 9 925 719 Body nut ST6.3-10 4
                51 11 1 908 077 Expanding rivet 6
                51 11 1 922 768 Hex head screw B6,3X22 4
                51 11 1 945 913 Stopper left 1
                51 11 1 945 914 Stopper right 1
                51 11 1 953 097 Bracket front left 1
                51 11 1 953 098 Bracket front right 1
                51 11 1 953 643 Spacer 10
                51 11 1 964 186 Expanding rivet 10
                51 11 7 070 183 Hex nut with plate M8 6
                51 11 8 103 009 Fillister head screw M12X90 2
                51 12 1 946 168 Fit bolt 6
                63 13 1 369 303 Fillister head screw 4
                Rear
                07 11 9 927 022 Collar nut M8 8
                07 14 6 961 200 Hex nut M6 4
                51 11 1 908 077 Expanding rivet 10
                51 12 1 946 168 Fit bolt 8
                51 12 1 965 859 Bracket rear 2
                51 12 8 100 420 Screw ST5X8,5 2
                51 12 8 100 422 Cap 2
                51 12 8 106 569 Bracket rear left 1
                51 12 8 106 570 Bracket rear right 1
