Rear Quarter Popout window
  • matt_vo
    • Mar 2007
    • 30
    Hi,
    I was wondering if all models of coupes, in other words all years, have the exact same popout windows?
    I'm asking because I just bought a used popout window and there is a difference in that the one I bought, from an '87, has a rubber weather strip around it, while my current ones don't. And since my car was rear-ended , I'm wondering if my windows were replaced with the right ones or not.
    Also, are the sizes the same?
    Thanks,
    Matt
  • AndrewBird
    The Mad Scientist
    • 11898
    Some didn't come with pop-out windows. My guess would be you got glass from a non-pop-out car.
    It could be the glass is different between early model and late model cars do to the different rear fender arches.
    • NomadE30
      • Mar 2007
      • 236
      well i am guessing that early models have weather strips on the windows, and late models have them on the actually body, never hurts to have two weather strips. I know my friend stole the back windows off our parts car 88 325i and put them on his 87 325is. So i am guessing in 89 is when they started switching over
      • whelton70
        • Mar 2004
        • 115
        I believe when BMW did the update to the e30's is when the rear windows changed as well. Pre 88 had pop out rear 1/4 windows and post 89 had non pop out rear 1/4 windows. When they went to the short bumpers and black body side trim and window trim is when the windows changed.
        • VAPORBLADE
          • Sep 2006
          • 1771
          I have an 89 with popouts - factory.
          One of the windows had been replaced by the looks of it. All is the same buy the BMW logo on the glass. One is full white and clear, the other is white lined and clear. On the roudel.
          '89 "is" = M technic II build mode.
          • matt_vo
            • Mar 2007
            • 30
            Well I just replaced my window and the sizing is perfect, so I guess windows from early popout e30s fit in later non-popout e30s.
            The only thing is that the black moulding that holds the window in place, the b-pillar, is springy, meaning that I can press on it and squish it against the car by about 1/4 inch and it'll spring back out. Is this normal? My previous window's trim fit snugly. Just a minor problem though.
            Matt
            • VAPORBLADE
              • Sep 2006
              • 1771
              Normal. I have seen it many times.
              • matt_vo
                • Mar 2007
                • 30
                Thanks,
                Then if all went well, I might swap my other window with a 'proper' one.
                By the way, since the used windows I bought were from an '87, they had the chrome trim. I painted them with satin black paint and they came out perfect.
