sap removal???
  • george graves
    • 19998
    sap removal???
    I've never had sap get on a car before - and now, I've getting the picture that you need to remove ASAP. I didn't and now it very hard.
    What have you guys used in the past that works well?
    I did some searching on the internet, but I wanted to hear from someone who had to do this first hand.
    Thanks!
    Originally posted by Matt-B
  • Bill-B
    • Apr 2007
    • 1242
    Just had the prob on the other message board
    This website is for sale! euroteknik.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, euroteknik.com has it all. We hope you find what you are searching for!
    Originally posted by NavyE30
    I saw Vlad was posting and got excited. Then I saw there weren't any boobs and was sad.
    • Bill-B
      • Apr 2007
      • 1242
      Rubbing alcohol (highest percentage you can find 90% will do) mixed with water 50/50 for 90% slightly less for lower percentages. After washing the car you can spray on and let dwell. Should soften it up and make it come off...you can always try clay as well.
      I think this one works best
      • Desaevious
        • Aug 2007
        • 3810
        I use mineral spirits. Shit works like a charm.
        SC*AR (Schwarz Army)
        • george graves
          • 19998
          I tried alcohol the drug store kind, and it seem to mar the paint, mineral spirts do nothing. I was brave enough to try castrol "Super Clean" - and it seems to work, I'm just worried about long term effects.
          • Bill-B
            • Apr 2007
            • 1242
            Did you mix the alcohol with water?
            • thereisnoyun
              • Feb 2007
              • 2301
              alcohol? I think not
              seriously... are you considering using rubbing alcohol on your car? sounds like its going to rip the paint off like paint thinner.
              I actually have realtime experience myself on my e38. If you own a good orbital buffer, take some paint cleaner from einzette or mequire and go to town with that, if its stuck for a long time use some polish. I wish I had taken some picture. you can take those things off easy, but dont even bother if you dont have a good orbital polisher, get someone who does and help you out.
              • thereisnoyun
                • Feb 2007
                • 2301
                long term effects? you fucked up your paint... short term? it'll dull out like crazy. and you would need to get someone to polish it anyways after your done with your crazy endeavor.
                • Bill-B
                  • Apr 2007
                  • 1242
                  The guy that said to use alcohol is a pro detailer, does the work on Lambos and Euro show cars and such, I doubt that he would give bad advice
                  • george graves
                    • 19998
                    Nope - I didn't - I'll try that.
                    About the "long term effects" - I HAVE to try something, or the LONG TERM EFFECTS are a sap covered car!
                    Super Clean is nasty stuff, we all know that, but it seems to strip some oils out of the paint for a second, then following with a coat of solid wax puts them back.
                    The car is zinno BTW...
                    • atomic
                      • Jun 2007
                      • 5691
                      You can get some goof off from the home stores(lowes, home depot) and use it to wipe the effected area. If it is real thick you might have to carefully use a single edge razor blade and shave it down close to the paint surface, so you are not rubbing all day long and scratching the hell out of your paint, then wipe it with the goof off... When I worked at the local BMW dealer we used a product called ACUSOL. The sap will not hurt the paint as long as you find it and remove it quickly but once it has had time to sit and bake in the sun some(several hours) it can start to etch the pain(similar to bird shit) and then a more drastic measure will have to be taken to get the etching out of the paint(wet sand and buff area effected) Take a look at page 15 on the BMW paintwork assessment that I posted here http://www.r3vlimited.com/board/showthread.php?t=92311
                      • VAPORBLADE
                        • Sep 2006
                        • 1771
                        Want it gone quick?
                        SIMPLE GREEN!
                        '89 "is" = M technic II build mode.
                        • old3
                          • Sep 2006
                          • 58
                          Whatever you do don't use a single edge razor blade on a painted surface! They do make a plastic razor blade that could be used to remove large globs of sap. The simple green in a diluted form will help clean it off. After you use a strong cleaner like simple green on an automotive finish use clay bar, like the kind they sell at www.griotsgarage.com or Mothers or Meguires to clean the surface completely and get a couple coats of wax to seal the surface. Then never park under the "sappy" tree again.
                          1989 325i
                          1998 Volvo V70 GLT
                          1977 Rabbit itc
                          1996 Ranger 4 cyl (real dog)
                          2004 Passat 1.8 Turbo
                          • browntown
                            • Jun 2004
                            • 3524
                            um, they sell bug and tar remover at every autoparts store in the country. Works great
                            • rede30
                              • 4697
                              I have used some of this xbrand stuff and it has worked very well for me.
