M-Technic II drilling patterns and diagrams
  • Jordan
    • 12913
    Someone is bound to have some of the diagrams indicating where holes need to be drilled for clips, screws, etc.
    Also does anyone have a comprehensive list of all the hardware needed to mount the complete OEM kit?
    https://mtechniqueabs.com/
  • golde30
    • 11464
    this is from realoem. this is just the front bumper. u can find it all though, i put in: E30: 325i: Europe: 01/1991
    then go: vehicle trim - and its all there...
    02 INSTALLING SET SPOILER FRONT M TECHNIC 1 09/1987 51112239709 $460.91 See ABE 9786216, EBA 9788634
    02 SPOILER FRONT M TECHNIC 1 09/1987 51712239865 ENDED
    03 CLAMP M TECHNIC 7 09/1987 51712239711 $0.56
    04 EXPANDING RIVET 8 09/1987 17111712963 $0.27
    05 CLAMPING BOLT 2 09/1987 51711933719 $1.40
    06 CLAMP 2 09/1987 51711922599
    07 PLASTIC NUT M6 2 09/1987 16131176747 $0.48
    08 AIR CHANNEL LEFT M TECHNIC 1 09/1987 51712238867 $26.51
    08 AIR CHANNEL RIGHT M TECHNIC 1 09/1987 51712238868 $25.95
    09 GASKET M TECHNIC 1 09/1987 51712239713 $11.83
    10 FOIL M TECHNIC 1 09/1987 51712239714 $4.02
    11 DRILLING STENCIL M TECHNIC 1 09/1987 51712239841
    12 RETROFIT KIT, TRIM PANEL M TECHNIC 1 09/1987 51112239700 $374.98
    12 TRIM PANEL M TECHNIC 1 09/1987 51112239864 ENDED
    13 CLAMP M TECHNIC 8 09/1987 51112239701 $0.37
    14 EXPANDING RIVET ? 09/1987 51111908077 $0.22
    15 EXPANDING NUT M TECHNIC 2 09/1987 51112239842 $0.27
    16 BODY NUT B4,2 4 09/1987 51112239707 $0.73
    17 FILLISTER HEAD SELF-TAPPING SCREW ST4,2X19-Z2 4 09/1987 07119907809 ENDED
    18 WEDGE M TECHNIC ? 09/1987 51112239702 $0.23
    19 GUIDE LEFT M TECHNIC 1 09/1987 51112239703 $5.80
    19 GUIDE RIGHT M TECHNIC 1 09/1987 51112239704 $5.84
    20 BRACKET FRONT LEFT 1 09/1987 51111953097 $9.93
    20 BRACKET FRONT RIGHT 1 09/1987 51111953098 $9.93
    20 SUPPORT BUMPER BRACKET LEFT M TECHNIC 1 09/1987 51112239705 ENDED
    20 SUPPORT BUMPER BRACKET RIGHT M TECHNIC 1 09/1987 51112239706 ENDED
    21 COVER M TECHNIC 2 09/1987 51112239708 $9.60
    22 HOLDING STRAP 2 09/1987 51111938263 ENDED
    22 HOLDING STRAP 2 09/1987 51111973721 $0.56
    23 SPACER BUSHING 4 51112238833 $0.21
    24 SUPPORT M TECHNIC 2 09/1987 51712238866 $2.79
    IG: @Baye30
    • Jordan
      • 12913
      Thanks... but I'm looking for a list based off someones experience. I have seen all the parts listings on REALOEM and I see alot of items I know aren't needed or have quantities either wrong, or not listed at all.
      The side panels and skirts are my major concern, then the rear bumper. I will be running a fiberglass front so I can modify it so mounting that will be custom anyways.
      • VAPORBLADE
        • Sep 2006
        • 1771
        I will let you know soon...I have everything sides skirts will be here soon (hoping), pods/panels, bumper cover, front valance, rear bumper cover/valance, wing - all OEM. I have started going through all the hardware I need. I will be building a list as I go.
        I might have extra items of some things (not a real bad thing IMO).
        I also have the template for doing the front valance, and rear lower quarters (for the rear bumper valance). Like I said, it is all OEM.
        '89 "is" = M technic II build mode.
        • 92 mtechnic cabrio
          • 4907
          go to the bmw dealer and ask for mounting sets
          R.I.P 07/01/09 - 04/23/10 :(
          • Teaguer
            • Sep 2004
            • 6167
            I've got the OE mounting instructions and parts list pamphlet for the rear bumper/valance .
            For a small fee I can let you peek at it . :D
            • Jordan
              • 12913
              Ha.. how about I charge you a storage fee on your ECU, coilpack, and AFM?
              Vapor... keep me posted!
              • VAPORBLADE
                • Sep 2006
                • 1771
                Will do! Do you want to barrow the templates? They have been drilled though one time! ;) They worked for me, but I do want to hold onto them.
                • Jordan
                  • 12913
                  For the sideskirts and panels surely, but I don't need them right now.. still have more parts to find! Appreciate it and I'm sure I will take you up on the offer at a later date.
                  • mbonder
                    • 2255
                    I have the templates for the side skirts and I have front fenders off a 92 mtech cabbie to show me where to drill for the front panels. As for hardware, I'm still piecing it together, but I should have a pretty comprehensive list soon. I'm hoping to get the whole kit on by the middle of october, all mounted and painted.
                    Matt
                    • PУCCKAЯ_e30ka
                      • Jan 2006
                      • 1226
                      I would check e30 zone if I were you!
                      • xLibelle
                        • Aug 2004
                        • 2673
                        if the IS skirts are the same mount points, i will report back as much within the week. i would size up my kit for mount points but the kit is 4-door and wont fit my 2-door.
                        mbonder, can you post the skirts measurements to see if what i acquire are the same?
                        sorry for the OT, but why'd you sell the e36, J? welcome back, btw
                        • fast1eddy
                          • 40
                          I just removed the kit from my 92 Mtech cab. No its not for sale. There's a lot of hardware under there and some of it will break. I would suggest getting a few extra clips. I just ordered a new front spoiler and a few clips from the dealer. I'll be remounting everything in a couple weeks when the parts come in. I'll let you know how it goes.
                          • xLibelle
                            • Aug 2004
                            • 2673
                            fast1, take some measurements of the holes since you have the pannels off.
                            pictures help define your measurements. thanks
                            • xLibelle
                              • Aug 2004
                              • 2673
                              I could use these measurements!! (just the skirts actually)
