Diving Board Surround Material Question
  • Ray McCooney
    • Jun 2006
    • 1088
    I was just wondering at what point it would be considered not worthwhile condition wise on the plastic bumper surrounds for painting. I currently have the following condition on the front and rear bumper surrounds on my '87. I was going to touch up the surrounds at the same time as I paint my diving boards when I tuck them. Should I just find more suitable replacements to use as a base, or will a degree of sanding and prep work out fine for the ones that I currently have?
    Pic:
    Any help will be greatly appreciated. Thanks.
  • ANDRÜ
    • 1020
    Well if you paint them as is the final product will be rough like the surface is now. I would try sanding the surrounds nice and smooth, then paint them. If that doesnt work just get new ones maybe...
    • Ray McCooney
      • Jun 2006
      • 1088
      Yeah, that was my initial intuition. I have never payed attention to how much these surrounds go for in the used market. Perhaps it would just be better to find some smoother/cleaner ones to use as a base instead of trying to make the current ones work with more effort than they probably deserve. Thanks for the insight.
      • AndrewBird
        The Mad Scientist
        • 11897
        It's hard to find good used ones as they all did they same thing; warp and pit like that. The problem is, new ones are spendy.
        I would try sanding them before paint and then go from there.
        • ddavidv
          • 344
          Try sanding them. You may have to get a bit neanderthal on them to really clean them up. If you've got any bad gouges or pitting, you could probably fill it with epoxy.
          • Ray McCooney
            • Jun 2006
            • 1088
            Good Deal, looks like I'll be getting to work. Thanks Nitro and Ddavid. Any recommendations on sand paper grit?
            • StereoInstaller1
              GAS
              • 22679
              I wonder if a thorough cleaning and starting off with a high build flexible primer would work...them is nasty!
              As far as sandpaper, if on a DA, I would say 320. If by hand, nothing under 400, maybe even 600.
              GL!
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • Ray McCooney
                • Jun 2006
                • 1088
                GL!
                Luke
                Noted. Thank you sir.
                • Apex381
                  • Mar 2004
                  • 740
                  Good luck to you. I never had any luck trying to recondition any, and I've been through about 3 sets of surrounds now. As soon as I sand them and paint them where they look good the damn things start warping on me.
                  1987 325is - sold
                  2001 330i - New DD
                  • Ray McCooney
                    • Jun 2006
                    • 1088
                    Greeeeeeat! Oh well, thanks for the insight. Euro bumpers anyone??? :)
                    • Apex381
                      • Mar 2004
                      • 740
                      I think you could try the surrounds for the cabrios or buy a set new. If I rember correctly they are not made of rubber and are meant to be painted. In my opinion after you spend all the money for new surrounds and trim and paint and other materials you could have bought part of a euro bumper set or small bumper swap. I gave up and I'm converting to small bumpers:D.
                      1987 325is - sold
                      2001 330i - New DD
                      • Ray McCooney
                        • Jun 2006
                        • 1088
                        Hmm. Interesting. So then cabrio surrounds are a direct swap. The rational side of me does find the idea of just finding Euro bumpers from the get go more and more appealing. Thanks yet again.:)
                        • AlarmedBread
                          • Sep 2006
                          • 1510
                          It's a urethane, I had the same type of flaking on mine and sanded it with a 180 feathering disc, then filled the deep pits with the same urethane epoxy I was using to delete the side markers (it's a two part mix in tip type, can look what brand if you want). This got them pretty smooth and the epoxy sanded nicely, I used a little glazing putty to fill in the pinholes then a coat of sand able primer, sand again, trim black, wet sand and they come out pretty nice. Just takes some patience.
                          • ToplessE30
                            • 4791
                            I have some front convertible surrounds for sale if you want them
                            Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
                            • amdspitfire
                              • Mar 2006
                              • 254
                              whats the purpose of wet sanding after painting? What kind of grit should be used?
