Does the Rebar un-bolt from this bracket?
  • e30_kid89
    • Apr 2006
    • 489
    Theres a torx flat head bolt on the other side of the rebar that those 3 nuts are threaded to. If were to un-bolt it from the other side, would i be able to pull the rebar off the bracket?
    This is Josh's pic btw.
  • Teaguer
    • Sep 2004
    • 6167
    Are you just trying to remove the cover from the rebar ?
    I''ve never tried to remove the shock mounting brackets complete with the studs , just removed the nuts and removed the bracket bare .
    not sure what you are trying to accomlish but I guess you could just give it a try by removing the torx bolts on the front side .
    • Jordan
      • 12913
      Yes.
      https://mtechniqueabs.com/
      • e30_kid89
        • Apr 2006
        • 489
        Would you happen to know the torx size by any chance? It looks like a either a t-35 or 40.....I tried my t-30 bit and it was too small by a bit.
        • Jordan
          • 12913
          Its T-40.
