Floorboard metal?
  • Mastrcruse
    • Sep 2005
    • 5340
    Floorboard metal?
    What metal is our floorboards made out of? It might be a stupid question but I just want to make sure.
    I got naval rust jelly and it can't be used on some metals so I want to double check.
    Thanks
  • Jordan
    • 12912
    Same mild steel as the rest of the car...
    https://mtechniqueabs.com/
    • Mastrcruse
      • Sep 2005
      • 5340
      Alright, thanks Jordan.
      Anyone know if it is safe to use Naval rust remover? I have some surface rust on the floor and just bought 2 bottles for the M30 block.
      • Justin B
        Sikky Nar Nar
        • Mar 2005
        • 4273
        Use it, it's a kinda slow process with that goop so be sure to wire wheel away as much scale and loose crap as you can to begin with. If you dont you'll just turn out to make a bunch of brown jello before it gets to actually do anything to the lowest rust. Get it to the point where it's just sort of pitted brown metal rather than really rough, you've gotten the rust down to the surface past the scale. If it's really badly pitted though I'd suggest cutting it out and fabbing up some patch panels from some sheet metal found at a local hardware store.
        • Disaster Inc
          • Oct 2007
          • 429
          A quality rust converter, like the one SEM has is a lot easier to use than naval jelly IMO.
          Chris
          • Justin B
            Sikky Nar Nar
            • Mar 2005
            • 4273
            Agreed, I've used a product called Picklex 20 with good results as well.
            • Mastrcruse
              • Sep 2005
              • 5340
              Chris
              What does the converter do with the rust? Does it dissolve the rust, like the naval jelly? Also, would it be good enough to use on a block?
              • Disaster Inc
                • Oct 2007
                • 429
                Here you go...
                Chris
                • Mastrcruse
                  • Sep 2005
                  • 5340
                  Wow, never heard of the stuff. Looks like something to look into. Thanks for the recommendation.
                  • golde30
                    • 11464
                    sounds like por15.
                    IG: @Baye30
                    • delphini
                      • Apr 2006
                      • 680
                      FYI -i've also seen spray converter that comes in an aerosol can.
                      :pimp:
                      • Dave
                        E30 RAT
                        • 11675
                        POR-15 is a good option. Eastwood makes a similar product IIRC.
                        Current Cars
                        2014 M235i
                        2009 R56 Cooper S
                        1998 M3
                        1997 M3
