i got the guide on the main page of r3v for the shadow line trim, but i dont know whats the best way to take off the key holes, trunk lock (should i just tape around it?) and bottom door trim. i am having the front and rear glass removed tomorrow. anyone that has gone through this that has any hints can give me some tips.
Painting Prep / Trim Removal
the door key holes just take off the round plastic around it with a plastic pry tool (or a screwdriver with some tape on it) and mask the actual key hole. Its a PIA to remove the actual locks same goes for the trunk lock, you will have to re-adjust the trunk later. And the lower moldings, just get underneath them with a pry tool and slowley pry em off, get readly to go to the dealer and get some new molding clips (pretty cheap) cuz the are dry and brittle and will crack.harry/harout
