Trunk lid swap?
  • Lair
    • Apr 2006
    • 1553
    Trunk lid swap?
    I have a '91 318 convertible, and I want to get rid of the butt-ugly third brake light.
    I found a 4-door trunk lid in the right color, but I don't know if it's the same size as the convertible lid.
    Does anyone have any first-hand experience with this swap? Measurements from a four-door lid would work also.
    McCain's military draft: Are you willing to bet your life?
  • Sean
    • 5793
    Not first hand - but I've heard of this exact thing being done. All trunks should be identical - except of course for the M3
    - Sean Hayes
    • td325ic
      • Feb 2006
      • 780
      The deck lid from either a e30 coupe or sedan will swap just fine onto a convertible. I've done the swap myself and it's very straightforward.
      The only problem I need to fix on mine is that the right side of the deck lid sits a little bit lower than the left. It can be adjusted and shimmed until it's level but I'll save that for another day. I also think the trunk lift shock on the convertible is known to play a factor in the misalignment of the deck lid. I know other people have posted before about that.
      I'd recommend though that before you remove your convertible's deck lid that you take note of the placement of the mounting bolts. Also keep track of any shims that may have been used. This will make it easier to get the new deck lid aligned and positioned right.
      • fporro
        • 1859
        ^ I'll second that.
        here's my 87 Zinno iC with a 89 iS lid.
        • Kwaaahhh
          • Apr 2008
          • 843
          After seeing your post, I'm definitely going to do the swap! :up:
          Also any big difference other than the loss of the 3rd brake light? What did you do with the wiring?
          • StereoInstaller1
            GAS
            • 22679
            ZOMG, that car only has 2 brake lights, oh noes!
            Sweet, Frank. Looks hot!
            Luke
            Closing SOON!
            Thanks for 10 years of fun!
            • LEANE30
              • Apr 2006
              • 838
              Luke
              X2:up:
              just now gotta space the rear wheels out so they match the front's body offset!
              that iC looks so good it's makin me want one BAD ...maybe it's just the fact that spring is upon us ;)
              ...what hasn’t been done to an m20 yet?
              m20 Oil Stencil
