front/rear lower valence fixxer-upper
  • sirsteezo
    • 577
    I wanted to ask what I could use for my valence's?
    I want to clean it up, get the black overspray off and spray it to the closest red I can get.
    front-
    rear-
    -Steven
  • kamotors
    • Nov 2007
    • 7102
    krylon fusion red is kinda close i painted my rocker panels with it and nobody could tell the difference except for me.
    7speedshop.com
    • sirsteezo
      • 577
      ok, what would you recommend to clean up the valences with?
      • AndrewBird
        The Mad Scientist
        • 11898
        Castrol Superclean works great on just about anything. Go to town with a scrub brush. You might find a lot of "dirt" won't come off very easily though as tar, grease and all kinds of other stuff accumulate there. Might have to resort to a solvent of some kind like mineral spirits or acetone. But be careful if you do as they can screw up your paint as well.
        • sirsteezo
          • 577
          thanks for the tip!
          • JasonC
            Site Manager
            • 14451
            Looks like there is some rust to take care of also.
            edit: Also you maybe able to have a local automotive paint shop/store put the color of your car into a spray can( not alot may do that, so you'll may have to check around). Your color code is on the drivers side strut tower, get the name and the code number thats on it then they can mix up a can for you.
            1992 BMW 325iC
            1978 Chevrolet Monte Carlo
            • jw 325ic
              • Sep 2006
              • 1360
              towerpaint.com or paintscratch.com for colormatched paint. otherwise you might even try wetsanding if its overspray. googone+rubbing alcohol works for things like this also.
