how to get trim off doers and bumpers?
  • deutschman
    • May 2008
    • 5958
    i did i search and couldn't find anything about this. how does the trim come off a 9191 318i's doers and bumpers? i would just go at it but i don't want to go braking stuff. i need to replace some of it and repaint all of it. how some one can help me out here.
    cheers!
  • jw 325ic
    • Sep 2006
    • 1360
    off the doors its just unscrewing a little 8 or 9 mm plastic nut youll see when you open the door and look around the door jam behind the trim, and then carefully pull it off the door. theyre pop clips so just pop it off. you may need to get new clips.
    the bumper on a plastic bumper car is same basic thing, just pop it out. go slow so you dont break the clips on the trim.
    • deutschman
      • May 2008
      • 5958
      thanks man! helped a lot!
      • dkbmxer002
        • Nov 2007
        • 1389
        so the plastic bumper on the front bumper (the black plastic unpainted part) is just held on by little clip things?
        • jw 325ic
          • Sep 2006
          • 1360
          theyre clips that are molded to the trim. if youve ever worked on an e36 its like those. just lightly tug em out section by section. a flat head will help, but use a towel around it.
          • td325ic
            • Feb 2006
            • 786
            See my post in this thread, it explains how to remove the plastic bumper trim without breaking the clips
