Now with the wing, and the under lid panel, I have a pretty heavy trunk lid. Anyway to keep it from slamming other than lowering it by hand really slow?!
Heavy trunk lid
Tags: None
cant you also put the spring on the back notch? that should give you bit more resistance?sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iTComment
Oh man, dont you guys know there are different tension bars available from the dealer? Designed for trunks with wings etc, lol.sigpicComment
http://www.realoem.com/bmw/showparts...85&hg=41&fg=60
Look at parts 7 and 8... ZOMG!!??!:"FKEKW)P#@_I!!!! ;)sigpicComment
What did you end up doing??turk@gutenparts.com
Originally posted by JandersonProperly placed zip ties will hold bridges together.Comment
I moved the spring on both sides to the back tab. It helped a ton - but it is probably not quite enough. I will get a new rod at some point. For now - it is good.'89 "is" = M technic II build mode.
sigpicComment
not as cool as you might think, they make your trunklid sit unevenYour signature picture has been removed since it contained the Photobucket "upgrade your account" image.
Originally posted by TimKninjaIm more afraid of this thread turning into one of those classic R3v moments, where Pizza gets delivered.Comment
