Painting Weather
  • e30nub
    • Jun 2008
    • 1741
    Painting Weather
    I want to respray my car, but have a couple questions. I know it's best to have a certain humidity/temp for the paint to properly cure, but what is that temp? Should I paint in my garage in the winter or spring? I was thinking spring, but am unsure. My garage is not heated and insulated either.
    Thanks bruddah man!
    I can haz halp?
    -Pierre
    1987 535is
    1988 325is
  • monty
    • Feb 2007
    • 665
    Spraying anything under 60 degrees you will be doing a lot of waiting (between coats that is). Each coat needs to flash off properly. Trapping the solvents in each coat is not good. When it comes to clear coating, good luck not running it if its below 60. People that have done a lot of painting at home or do it professionaly can make it work, but a newb will mess something up. I know because I was a newb once.
    • e30nub
      • Jun 2008
      • 1741
      I live in cali so spring time painting will be in 70's +
      -Pierre
      1987 535is
      1988 325is
      • monty
        • Feb 2007
        • 665
        Then your good to go. When your ready to spray and buy your paint and stuff just make sure you get the reducer that is right for the temperature. The reducer is the stuff you add to the paint to make it sprayable, it comes in different temperature ratings. Just ask your local autopaint supplier and they will guide you.
        • e30nub
          • Jun 2008
          • 1741
          Thanks a bunch! Any good reads on painting in general? EX: books to buy/recommend?
          -Pierre
          1987 535is
          1988 325is
          • monty
            • Feb 2007
            • 665
            Sorry man I dont know of any good how to guides.
            • DoriftuEvo
              • 236
              BMW Manufacturing keeps their clean rooms at 75 degrees. I don't have any experience with one-off automotive painting, but I'd bet that's a good temp to shoot for.
              • Justin B
                Sikky Nar Nar
                • Mar 2005
                • 4273
                PM'ed you. Besides the rest of what I said, for everybody else to see a good forum to read up on is here - http://autobodystore.com/forum/index.php
