M Tech II kit on early car?
  • ColdAccord
    • 5926
    I was thinking instead of doing the late model bumper swap, what about just buying front and rear m tech II bumpers from eurostyle, and modifying the rear to fit? that way I'd be working with fiberglass
    what bumpers would I use? (don't want to lose safety devices).
    I just really love the look of that m tech II kit.
    Originally posted by blunt
  • Jand3rson
    • 37587
    Oh, I can see this thread starting to swirl around the toilet bowl already...
    ColdAccord, you have to use the stock internals and rebar from the later style bumpers. All I have to say is good luck with this project, you are in for a WORLD of work. :up:
    • 318driver
      • 1714
      Andre did it right?
      minus the sideskirts
      90 325is
      IE stage 3s and refeshed m20....
      • bimmerphile
        • 3495
        Originally posted by 318driver
        Andre did it right?
        no, he used a fiberglass kit made for the older cars.
        • ColdAccord
          • 5926
          Andre did it right?
          really? I was pretty sure he had an m tech II kit modified. it was originally molded to his quarter panels, then redone the way it sits today
          Also, I would be using different sideskirts. Not too crazy about the m tech II skirts, nor do I want to do all that work.
          I figure a plastic bumper conversion would be a bitch, so why would this be any worse?
          • MattM20
            • 641
            you can use your diving board as rebar for the rear if you mount it 2" higher and modify the bumper shocks. i suppose you may be able to do the same for the front if you had a one-piece mtech2 bumper/spoiler but i can imagine mounting the fogs and turn signals would be a PITA.
            in your first post you kind of made it sound like working with fiberglass would be better than working with plastic. that assumption alone could kill any hopes you had of pulling this project off; it is much harder, and alot more expensive, to modify fiberglass than it is to modify plastic. you could trim the bumper ends that extend into the fender, but you would run into problems making the end plates. plus, you should never assume a fg replica piece is going to fit like a factory part.
            • ColdAccord
              • 5926
              the main thing is that I would prefer to have the M tech II kit to the plastic bumpers. if it doesn't work out, it doesn't work out, and I'll just do plastic bumpers
              just figuring since it would need a lot of work anyway, might as well do what I liked more
              • MattM20
                • 641
                thats fine. i feel the same way. its just putting on a mtech2 kit, even if its only the front and rear, will cost a whole lot more than getting plastic bumpers. you dont save any money with new fiberglass parts over used originals, and you would still need front and rear plastic bumper rebar and shocks, a front valance, fogs, and turnsignals, plus trimming and remounting the rear bumper. even if you find a good set of used fiberglass parts, it's going to cost alot in labor for a body shop to install them (the rear at least), plus there's a good chance they'll charge more to paint the parts. i'm not trying to disuade you from doing this, i'm just trying to help you make your decision.
                • Jordan
                  • 12916
                  Eurostyles kits are shit. Even one "made" for your car doesn't fit.
                  Just say no to Eurostyles kits.
                  https://mtechniqueabs.com/
                  • DSchultz325e
                    • Aug 2004
                    • 1158
                    for jase!!!1
                    I retired my E30 for now...
                    E46 323i
                    David Schultz
                    • Eurostyle
                      • Mar 2004
                      • 15
                      for jase!!!1
                      Sure, and guess what happened after his accident:
                      I am going to need a lower of the front of my kit. whats it going to cost?. it was a good fit and broke clean off. but is heavily damaged.
                      Jase
                      Now tell me, if the most unhappy of my customers comes back to me, what does that mean for the rest of them!? Remember, things are not always the way they seem to be, even after all that has been said, we are still cool and he is more then willing to business with me again
                      • themax
                        • Oct 2004
                        • 15
                        Let me through a question out there. I have a 325ic with the older bumpers. I was looking at changing the bumpers then going for the M tech II kit. Is the the order i need to go or can I go stright to the M tech II kit? Also where can I look for this Kit.....I can never get Lowen to return any messages for the kit.
                        • royalflush313
                          • Mar 2004
                          • 2070
                          Lowen as in Lowen Design? I have no personal experience with Lowen Design, but this is worth a look.
                          ~ Go Canucks Go! ~
                          • Dave
                            E30 RAT
                            • 11675
                            Stay away from Lowen!!!!!
                            As for the M-Tech, it has its own bumpers. They look kind of like the plastic ones but they are indeed different - no rubber impact strips on them. If you get a real M-Tech II, it will have bumpers. Check out Eric Lukas at lukasbmw.com. His is a two door hardtop, but you'll get the idea.
                            Current Cars
                            2014 M235i
                            2009 R56 Cooper S
                            1998 M3
                            1997 M3
                            • themax
                              • Oct 2004
                              • 15
                              Ha, thanks for the ideals. I will stay away from Lowen.
