I'm laying up the resin by hand, without a vacuum. The key is to use as little resin as possible for a stiffer, lighter part, and to use a roller to force out all the air. Vacuum bagging is something that I'd like to try, but not on a piece this large (and relatively simple). I was thinking that V2 would use clear gelcoat on the surface of the mold, as in I would apply the clear gel coat, then the first layer of carbon. I think it would provide for a more durable outer surface, and alleviate the air problem.
The tricky thing about carbon, versus fiberglass, is that you can't see the air bubbles through the fabric.
And as far as the bracing goes, I may just make a mold of the underside of the trunklid, then bond that piece to the underside of the carbon skin, but that would make this weigh more than twice as much.
