lookin to paint my car
  • iamsam
    • Jun 2008
    • 176
    Originally posted by Schwarz3
    yeah, as a fellow painter, I also remember my first clear coat: the complete opposite. Looked like an orange :D I was too scared of running it.
    hmm. kinda scary because i am about do apply my first clearcoat this summer on my 318is. Why are first clear coats always so bad? what are some tips you can give me so i can get a near perfect clear coat the first time?
    Thanks
    • DatUtahGuy
      • Jan 2007
      • 3146
      Thanks
      I can answer with only the most basic response: you have to "feel it".
      As absurd as that may sound, once you start applying the clear coat you will see how wet or dry is laying down, depending on what clearcoat you are using(I'm assuming a 4 to 1), it may be easier to get sags.
      I would say, spray it wet. If it doesn't flow even(meaning it doesn't look like the final product when you are spraying it) then you need to go over it again a bit slower to apply more product.
      Make sure you paint in a WELL LIT AREA. Can't stress that enough. Have plenty of light to get a good look at it from different angles, it should not have a rough texture but settle to a mirror-like finish.
      Just remember, it's easier to fix a run or sag because you applied too much clear than to smooth out orange peel because you didn't get enough on there.
      YOUTUBE: AR Perez
      If lucky, the E36 will die peacefully, in its natural habitat, and be given the prestigious honor of donating its parts to an E30
      • jrawk79
        • Apr 2008
        • 32
        Taking your car to maaco is like getting a tattoo from a homemade gun...
        spend the time and money and get it done right !
