Grommets stuck after good removal
  • ThomasE30
    • Mar 2020
    • 104
    So I ordered a new plastic badge on amazon for the “trunk and hood” for 10$ on amazon to see if it would fit the trunk. The trunk one currently on my e30 is a lot worse than the hood so I figured it doesn’t fit then I can just put in on the front since it fits there for sure. After taking out the old metal one on the trunk, I cannot seem to get the old grommets out. Any ideas how to?
  • roguetoaster
    Biggus Tippus
    • 7830
    Cut or score around the overspray at the grommet, then either put a correct size screw through (compare to your new grommets) and pull the screw or use a very small set of pliers to pull it out. Alternately you can cut it and push it through to the other side, but that's a bit risky.
    • ThomasE30
      • Mar 2020
      • 104
      Thanks I’ll try that !
      • ThomasE30
        • Mar 2020
        • 104
        Okay so I was able to get the left grommets out but the right’s flanges came off and it is now inside the hole. Is there a way to get in side there or am I just shit out of luck
        • roguetoaster
          Biggus Tippus
          • 7830
          SOL, but it will probably wedge itself in somewhere after a bit of rattling.
          • ThomasE30
            • Mar 2020
            • 104
            Okay atleast it’s out. They really could’ve done that design a bit better.
            • brutus
              • Dec 2016
              • 596
              ,, hi,
              before u go further ,, the trunk ones dont usually dont fit the ones on the hood,,
              very slight different sizing, and @ 10$ I really think its gonna be mickey mouse made in china !
              sorry,,,,
