I’m not sure exactly what happened but I was looking for some advice on realignment of the front valance with the grills and if this is something I could do on my own without taking to a body shop.
Advice on fixing front valance
If you take the bumper off and the grille, the valance is quite flimsy there - put a length of wood the thickness of the pressing behind the valance to use as a drift & a mallet should make short work of it. Just take your time & don't hit it too hard - you may even be able to put a piece of wood behind there and pull on it to straighten it out with just your hands. Alternatively you can get a set of proper dollys but it's a pretty small repair, so a ghetto fix is probably as good as anything.Comment
Thanks! exactly what I was looking for.If you take the bumper off and the grille, the valance is quite flimsy there - put a length of wood the thickness of the pressing behind the valance to use as a drift & a mallet should make short work of it. Just take your time & don't hit it too hard - you may even be able to put a piece of wood behind there and pull on it to straighten it out with just your hands. Alternatively you can get a set of proper dollys but it's a pretty small repair, so a ghetto fix is probably as good as anything.Comment
