Hi, Is there any easy way to remove the broken clips for the front valance lip? Thanks.
How to Remove Clips for the Front Valance Lip
Tags: None
There's a plastic insert inside the tab that holds the clip in place. What I do is push the insert out with a small tip phillips head, then squeeze the tab with pliers and it should pop right out.
If theyre old they may be hard to push out. Since youre not re-using them you can just hammer it out from the face of the clip..-Jay
2014 NASA FL se30 champ #81
2001 se46 3 year plan in progress
