Front valence clip replacement
  • danalyse
    • Apr 2009
    • 153
    About to reinstall my front valance. Ii have noticed that all of the clips are broken and i shall order seven new ones from the dealer. Does on need to remove the bumper cover to get the old ones out and the new ones in.
  • FredK
    • 14762
    The clips that secure the valance lips? If so, no. You can use a screwdriver to remove the old ones.
    • bmws50b30
      • Aug 2005
      • 1151
      it's a bitch to remove if you're not doing it right. look under each clip and you'll see circles at each end. use something to push it upward and pop it out. once out you can just pull the clips. look at your new clips and you'll see what i'm talking about. you'll push these pins in to install the new ones.
      1991 330is
      • TrentW
        • 2815
        And I believe you'll need a total of ten if they're all broken.
