Trunk Lock
    Trunk Lock
    Mods: If this is in the wrong section - I apologize in advance!
    Hey folks,
    I've noticed that my trunk lock has become rather difficult to lock and unlock. The best way to describe it is that it is very "stiff" to turn. Is there anything I can do to fix this problem? TIA!
    1989 E30 BMW 325i
    1998 E36 BMW M3
    2004 E46 BMW 325i
    oil/grease back of it, if not check to see if key is worn...
    replace as needed
      Thanks for the reply, Matt-B. Any particular oil or grease recommended?
      Here's something to throw things off:
      When it was snowing for the several days in Vancouver (Canada) last month, the lock would be ice cold/frozen and/or covered with snow. At that point in time, I could literally slide the key into the lock and lock/unlock with ease.
      Now, I can't. :(
      1989 E30 BMW 325i
      1998 E36 BMW M3
      2004 E46 BMW 325i
        I used wheel bearing grease cause that what i had and same issue happened to me... when it was cold it will work cause lock is frozen and Ill ry to explain why...
        guy at dealer (who sold me a new lock :() said the are like "teeth" that catch when key is turned and when lock wears out they dont grab cause there worn...but when it gets cold and icey moisture gets in there and "sticks" things together and can make it open...
        i ordered a new OEM 1 and it came with 2 keys...hope that helps
        ps I lived in Vancouver (washington) :)
          Thanks again!
          Was the wheel bearing grease a temporary solution or did the problem just come back time and time again until you finally gave in and purchased a new lock?
          1989 E30 BMW 325i
          1998 E36 BMW M3
          2004 E46 BMW 325i
            yea grease worked for a few weeks finally it stopped unlocking altogher then i bought a new one, i decided against buying used locks cause whats to say they wont go bad in a day?
            i had to jiggle key 500 times to get i to unlock lol
              Ouch!
              Would you happen to have a part number and a general idea of how much this will run me?
              1989 E30 BMW 325i
              1998 E36 BMW M3
              2004 E46 BMW 325i
                mine was 110$ for NON central locking
                central locking ones are 60-85$ i think
                51 24 1 904 514 NON central locking
                51 24 1 911 948
                For vehicles with:
                Central locking system = Yes
                  n00bie question:
                  When I turn the trunk lock, it also unlocks the other locks on all 4 doors - is this central locking or no?
                  1989 E30 BMW 325i
                  1998 E36 BMW M3
                  2004 E46 BMW 325i
                    yes it is, its best to unlock your car from trunk cause it saves all the wear and tea on driver lock...some of which dont work
                      Gotcha! My driver side lock cylinder is due for a rebuild so I think it's time to do that and to replace that trunk lock. Very helpful post! Thanks Matt-B! :)
                      1989 E30 BMW 325i
                      1998 E36 BMW M3
                      2004 E46 BMW 325i
                        yea no problem, gettin help should be easy :)
