Im wondering how the cab looks with a cage and a drop. Anyone have a pic?? Im debating wether to pull the trigger on a cabrio or wait til I find the hard top I want. Thanks
Cage in a cabrio??
Depends on the model of E30. Verts are about the same curb weight as the iX: ~3050lbs
Late model M20 cars are ~2850
Etas are ~2700
M10 cars are ~2450, M42 cars are 2600ish whereas M42 verts are 2850
So in general, 200lbs heavier than a comparable coupe/sedan is a good approximation.paint sucksComment
My '92 with a full tank and me (165lbs) came to 3300
Search for E30S50Cabrio, he has a cage in his 'vertComment
According to my door sticker, I'm somewhere around 3300. 1800 front, 1500 rear I believe.FS: assault gear....Originally posted by stoliver54Aw, balls.
http://www.r3vlimited.com/board/showthread.php?t=159253Comment
This is true. Hard top helps stiffen it up a lot as well.Depends on the model of E30. Verts are about the same curb weight as the iX: ~3050lbs
Etas are ~2700
So in general, 200lbs heavier than a comparable coupe/sedan is a good approximation.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
.....DO WANT
Awesome! I spent about two hours removing my AC, but you just lightened it another ~300 lbs in one post! Thanks!
Maybe I'll actually weight it eventually, after new engine, cross brace etc are installed, but that's pretty low on the priority list.
It's even lower than doing homework, which is not getting done.......thanks to r3v. :mrgreen:FS: assault gear....Originally posted by stoliver54Aw, balls.
