Thinking about rusting my trunk
  • moe30
    • Jun 2010
    • 721
    First off... if you are going to be negative please don't post. I know people hate it and think it looks dumb... still don't care.
    Anyways, I'm want to go to the yard and find me a wingless trunk to rust and I'm gonig to save my nice red trunk for if I hate the rusted look... I'm need a little guidance on how its done.
    I know I take it down to metal and get it good and cleaned off.
    But after that should I let it do it naturally or use chemicals?
    If chemicals which ones work?
  • SpecM
    • Oct 2005
    • 4531
    road salt + water solution
    wipe it on, let it set for an hour, hose it off
    it'll take a few weeks after that to really "rust over"
    might be a good idea to clear-coat over the rust, once the desired effect is reached, to prevent any further rust
    1989 cirrisblau-metallic 325i
    • SeriousBusiness
      • 428
      A lot of people use vinegar and a warm salt water solution. For smaller objects you would soak in vinegar overnight, spray a hot salt water solution over the piece, and then allow it to dry naturally. Spray with water occasionally during the drying process as this speeds up the rusting a bit. After awhile of drying/wetting, wash off the piece with just water and blow it dry with an air nozzle or something similar. After that you can let it rust naturally or clear it to slow the process down.
      Hope this helps, post pics when your done and how you did it.
      EDIT
      Here is an interesting method if your resourceful and have the balls to try it:
      You'll need a source of DC electricity, a tub of water and some salt (maybe a tablespoon). Connect a piece of steel to the positive output from your DC source, stick that in the water, and then stick the negative output into the water (but don't let the two touch). Switch on your power supply and let it sit, I usually do this overnight. Make sure you unplug your power supply before attempting to get at the sweet rust meats inside (I think this goes without saying). BE CAREFUL NOT TO ZAP YOURSELF!
      EDIT
      Or if you REALLY want to go all out:
      I finally found the right combinations to create 100 years of rust in two day process. I'll start with the chemicals, the amounts will very depending on your surface area. I'm basing on 4' x 4' x 1/4" steel both sides.
      Chemicals:
      1 gallon Distilled Water
      1 pint MEK / methyl ethyl ketone [link is to product info at Amazon]
      2 pints Muriatic Acid [link is to product info at Amazon]
      1 half gallon Hydrogen Peroxide [link is to product info at Amazon] (Semiconductor Grade)
      1 Cup Sea Salt, Course [link is to product info at Amazon] (Table salt has Talc and will affect the final look)
      1 Cup Iron Filings [link is to product info at Amazon] or Ferric Oxide
      Tools:
      1 Pair PVC Gloves “Acid resistant”
      1 Box Latex Gloves
      2@ 2" to 4" PVC paint brush
      1@ 2 gallon plastic bucket
      1@ Plastic Spray Bottle
      1@ Pizza Cheese Shaker
      1@ Water Hose
      Preparation:
      1. Have your target steel sandblasted to raw metal with an even texture.
      2. Find a well ventilated area with access to a water source and drain attach the hose to the water source.
      3. Mix equal parts Sea Salt and Iron Filings into the Pizza Cheese Shaker.
      4. Fill the plastic spray bottle with Hydrogen Peroxide set the spray pattern to mist and store in a cool dark place until needed. Use Latex gloves; this will burn your skin fast.
      5. Lay the intended rusting surface face up and flat. Using rags use the MEK / methyl ethyl ketone [link is to product info at Amazon] and clean any oil, dirt off the surface of the bare metal.
      6. Mix the Muriatic Acid and Distilled Water in the plastic bucket and let rest “Cool” be sure to use the PVC Gloves.
      Process:
      1. Using the mixed Acid and paint brushes heavily coat the surface of the steel and let stand for 15 minutes.
      2. Using the water hose rinse the Acid mixture off the surface of the steel.
      3. While the surface is still damp sprinkle the Sea Salt & Iron evenly over the surface of the steel.
      4. Spray the salted surface with the Hydrogen Peroxide and watch the rust form allow it dry and repeat steps 3 & 4 until you achieve the desired finish.
      5. Allow surface to dry thoroughly and continue to the next desired surface.
      1985 RX7 - Badassery Exemplified.
      1989 325is
      -Tom
      • thereisnoyun
        • Feb 2007
        • 2301
        just pull the paint off using paint stripper, then with bare metal put some vinegar over it
        you can also heat it up with bare metal with say torch or heat gun, then shoot water on it while its hot. Flash rust extreme!
        • StereoInstaller1
          GAS
          • 22679
          First off....fuck off.
          If you are gonna post about retarded ideas and stupid shit like a purposefully rusted body panel, please go find another fucking forum.
          "Don't hate on me, I just want it to look cool!!!!"...bullshit.
          Trendy little bullshit wanna be, lacking the originality to do anything new.
          Fuck off. I will hate or like what the fuck ever I feel, and right out here in the goddamn open. If YOU don't like it, leave.
          Rusted body panels suck donkey balls and so do the fucking idiots who "rock" them.
          Do something new or you are nothing but a trend whore.
          Closing SOON!
          Thanks for 10 years of fun!
          • TheCanuck
            • Jul 2010
            • 11
            Very few things on this forums should get you this worked up and this topic isn't one of them.
            People are naturally creative and its not the end of the world.
            Stop being a fucking paint nazi.
            My first car. Bought July 1st/10
            Working on fixing a bunch of little problems with the car right now.
            • StereoInstaller1
              GAS
              • 22679
              That ain't worked up. I get WAY worse.
              I am a paint nazi: shiny pretty paint is gorgeous.
              If you have to be "different", get some damn Di-Noc, do your fucking car in marble.
              Closing SOON!
              • JasonC
                Site Manager
                • 14451
                I'm with Luke on this. But if someone wants their car to look like SHIT, go right ahead and make it. But when you post up on a forum with guys that make their cars look shiny and presentable, expect to be flamed.
                1992 BMW 325iC
                1978 Chevrolet Monte Carlo
                • Mike The Bavarian
                  • 488
                  brake fluid works good at eating paint...
                  • moe30
                    • Jun 2010
                    • 721
                    I know its pretty hated, I come from Integra where I personally have hated on rusted hoods. I think that rusted stuff looks good on older style cars, e30's being one of them. Also I'm not sure that I'll like it, I'm going to try it on a junkyard trunk and if I hate it I'll still have my shiney red trunk w/ my iS spoiler to put back on.
                    I just want to try something new... for me.... I know other have done it but on my last two builds I did on Integras I did the paint only option, its very clean I agree but I just want to try it. I know everyone has an opinion but I didn't ask what do you guys think or how do you think it will look. Thats the only reason that I put that, because I've made up my mind that I'm going to try it... but it doesn't mean that it will stay on there.
                    Plus I hang out with another red e30 and our cars look very similar... and I have an issue with looking like everyone else, and no one else does rusted stuff in the midwest so I'm gunna try it. Just to make you feel better I hang out with a very clean plastic bumpered alpine white e30 w/ bbs rs's. I absolutely love the car. I'm not against cleanly painted cars... just want to try something new.
                    • 5KWattson
                      • Apr 2009
                      • 809
                      im kinda more on the shiny side, my hood is chalk board and it is kinda gettin old to me now...shiny=gettin laid. rust/faded/flat=palmala and her 5 friends IMO
                      "God created turbo lag to give V8's a chance" Taylor D.
                      • Jonny Cash
                        • 1763
                        Maybe its a lemons car, and he feels the car looks too nice. I have something up my sleeve for our Lemons car noone's done yet, it should be fun. Knowing how sensitive these guys are it should be a shit flingin contest.
                        BTW these guys are making it sound like a science when all you need to do is strip it down and rub it down with bleach. Although i think the only way to really pull of the rusted look is do the whole entire car.
                        -Jay
                        2014 NASA FL se30 champ #81
                        2001 se46 3 year plan in progress
                        • moe30
                          • Jun 2010
                          • 721
                          If my car wasn't as decent as it is I would be down to do it... but my car is pretty straight and the paint is pretty good.
                          • Mauiwowi
                            • Aug 2009
                            • 234
                            haha you guys are acting like little bitches over someone elses rusted car.
                            Thanks for the thread though, my high ass is going to do the trunk and the hood just to piss off the world
                            Girls, you can't be the first, but you can be next
                            325ix
                            • Jand3rson
                              • 37587
                              Vortex is ---> that way.
