Paint or replace exhaust tip?
  • SykoBMW
    • 1065
    The exhaust tip on my 92' 318iC is a bit rusted, but looks to be surface. I'm either going to just spray it with black spray paint or replace it. If I go the route of replacing the tip/muffler. Are there any good suggestions for tips/mufflers?
  • OldUser1
    • 636
    My exhaust tip on my 318is looked all crapped out. I took a type of sand paper (called shark tooth) or something along the lines of that, its used to clean up the ends of copper pipe. I sanded off all the crap on my exhaust tip. Now its clean, and shiny. My friends thought I bought an exhaust system....when all I did was clean my tip.
    • Rob
      • 8166
      try sanding the rust off, it my look better. If you dont like the silver look, hit it with the spray paint.
      BEERTECH
      • randomtask37
        • 3154
        mine was faded and dirty, so i just cleaned it off and sprayed the muffler/tips and the spare tire well flat black. it looked "different" at first, but now its grown on me and im glad i did it.
        98 M3/4/5
        • SykoBMW
          • 1065
          Went ahead and sanded off the rust with sand paper and a dremel. It looked horrible before, there was no silver showing through and rust all over,but now it looks great, just need to do a little touch up. What should I put on it to stop it from rusting again?
          • BloodLine
            • 210
            I'd need to see pics of it looks like if the finish could be saved.. I say get a chome tip.
