how to switch the VIN tag?
  • Gadea
    • 454
    When replacing a cracked dashboard with another one from another E30 (duh), how do you remove the VIN tags without causing cracks on the dash?
    1998 528i auto on staggered DSII
  • 'e30love'
    • 893
    Use a razor those clips are two one on top of the other, the lil ball up top just carefully slide a razor under it and it'll pop up after that your golden I just went through this.
    • Gadea
      • 454
      how do you then attach the old tag to the new dash?
        • 37834
        You can pop it out very carefully with a small screwdriver. If done right it should pop in to the "new" dash.
        Grover Beach, California
        BimmerHeads.com
        • StereoInstaller1
          GAS
          • 22679
          You need to smear grease all over your face and do it on a dark sidestreet, wearing a black jacket and a black beanie. You should also be carrying a brick.
          Closing SOON!
          Thanks for 10 years of fun!
          • ak-
            • 12422
            lololololol^
            Listen to Luke, he's been here longer.
            1991 325iS turbo
            • Gadea
              • 454
              • FredK
                • 14764
                Yeah, the part that gets popped up with a razor, small screwdriver, or rivet popping tool is a plastic rivet. It is easily extracted and reinstalled with a minimum of fuss.
                • elmercc
                  • Feb 2011
                  • 129
                  What if the dash was replaced, and they did not switch the VIN tags. Is there anyway to order one for your car? Does BMW sell replacement VIN tags for the dash?
                  (OO=[][]=OO) 1990 325i
                  • Gadea
                    • 454
                    Never heard of someone doing that, but I've been wrong before. I will try to switch the VIN tags tonight as suggested above. Somehow I thought it would be harder. Guess I just have to be careful enough not to apply excessive force when pulling the tag. Even more careful when removing the one I don't need.
                    • StereoInstaller1
                      GAS
                      • 22679
                      Back in Springfield, OR, our local dealer sent a parts driver out to my shop. Parts driver "pencil etched" (rubbed a pencil across a piece of paper) across the VIN under the hood and ordered me a new one for the dash.
                      It cost me $7.00
                      Delivered.
                      Luke
                      Closing SOON!
                      • Gadea
                        • 454
                        Did this today, I removed them all no problem, but only one out of 4 rivets made it. The two on the bad dash were so brittle they shattered when they saw the screwdriver coming. I'll figure out a way to re-attach the tag.
                        • swerved300
                          • Jul 2010
                          • 25
                          dude... in the future(for anyone searching for this, actually)- use an awl to carefully push each fastener up from the back; there's two small holes on the underside of the dash to do this. It will look like two little black mushrooms. then, so as not to put any strain on the 'cap' carefully slide a shiv under the vin plate and work it free.
                          1986 528e Cosmos mit M106
                          1988 M5 #14
                          1990 325is Alpine daily
                          1992 300ZXtt HKS stage4
                          • ck_taft325is
                            • Sep 2007
                            • 6880
                            Spoken like a true inmate!
                            He's got it down to a T.
                            Need a part? PM me.
                            • Gadea
                              • 454
                              one of my dashes had that foam that covers the underside over the holes you're talking about, and the holes on the other one were really pinholes. The fastener didn't actually go through them, so I think should I had used your approach it wouldn't have done any better. But I understand what you mean by looking at the fasteners now they're out.
