Does anyone know what size of bolts or screws I need to mount the front plate on a 91 318? Thanks
Front plate mounting
Tags: None
I used small plastic grommets. Inserted those into the original holes and used a screw from the outside of the plate. When the screw went into the grommet it spread the tabs out holding the plate in. Similiar to the sheetrock inserts you can use in your house.
Good luck!
do you know what size those were?
I don't have a lot of hardware after moving to try stuff out. :(Comment
you dont have the mounting holes on your plastic bumper? Hmmm, unless you have a filler piece or something you should have the holes. If you have the holes, i think you just need some standerd screws. Maybe just go to home depot and grab a few. They dont have to fit perfect, but you def. dont want to strip the plastic threads.
Kyle1988 M3, 97 840, 99 XJ
DILLIGAFComment
